What is the difference between the high and low outputs on the WE6SE? I generally understand the difference between high and low impedance headphones and the relative needs for volts or amps. When you have an "inefficient" but relatively low impedance headphone like the HE-5/6, for example, would selecting the low output actually offer more amps to drive them? Or in the case of an inefficient low impedance headphone would you go with the high output? I guess I need to understand what effect different gain settings have from an amp, or simply put I guess I don't really understand what gain is exactly?
From some of the more recent post I am coming to understand that I will need to learn how tube selection will effect power output.
I am asking this question because my HE-5LE's will arrive this week and after hearing so much about what it takes to drive them I want to know how I should connect them. I have in the past found that I often prefer the sound at a higher gain setting on my amps even with some IEM's and low impedance headphones, but I have selected on what I like to hear, not with the real knowledge of what the cause and effect is.
I was hesitant to go with an HE because of all that I've read about properly driving the 5's and especially the 6's and almost decided to order and wait for the LCD2's, but after listening to the 5's at a recent meet on the SE(I really enjoyed them) and after reading some good reports of them being adequately driven by the SE I am hopeful my Woo will be up to the task!
