If I recall correctly you prefer the 6FD7 in your WA6 right? That should be the best case scenario for power output on the WA6, just a tiny bit higher even than the 6DR7 used in Jack's chart. If the tube gain corresponds directly to output (I'm taking a leap on that one) then it would mean power output using a 6DE7 or 6EW7 is only a third of what is shown on the chart. I'm not certain if my understanding is correct though.
edit: oops, I had it backwards on the 6FD7. It has a gain of 64 vs. 68 for a 6DR7 or 6CY7. And the 6DE7 and 6EW7 has a gain of 17.5 so 1/3 power should be right. I think the 6SN7 is 20 so the difference between it and a 6DE7 would be minimal. Of course if gain and power output are not directly related I'm totally off base here.
