Woo Audio Amp Owner Unite
Apr 21, 2017 at 12:14 PM Post #39,616 of 42,298
I'm using the balanced and single ended Mytek outputs. XLR to WA5 and rca to V281 so I can make quick comparisons.
I'm going to roll more driver tubes to see if I can resolve this. Other than that I just love to look at and listen to music through the Woo. I may just live with it!
Apr 21, 2017 at 3:00 PM Post #39,617 of 42,298
You can also try the Tung Sol 6SU7GTY black glass brown base. A 6SL7 substitute. They are cheaper than most 6SN7 tubes. But they give a higher gain. A musical but detailed tube. Extendeds well on both ends with a nice soundstage.
Apr 22, 2017 at 11:23 AM Post #39,618 of 42,298
I have a box of 40 tested but unsorted 6SN7 tubes that I bought months ago.  I laid them all out and matched them up based on make, construction and test scores.  I tried a few pairs of what looked like NOS RCA and GE tubes.  I wasn't blown away with the results.  I found a Marconi and a Magnavox tube that were identical construction with a diagonal "O" getter between plates and identical plates right down to copper wiring and stampings.  These went in and were different from the start.  They certainly went a long way to improving the resolution and bumping up the treble clarity.  For now I'm satisfied.  I'll still try to find the Tung Sol Tubes as an option.
Apr 24, 2017 at 10:53 AM Post #39,619 of 42,298
Hello,
I'd like to know if someone find new production tubes for WA6SE powertubes  ( 6DE7, 6EW7, 6EM7, 6DN7, 6FD7) ?
I have search on google and many sites without success.
Thank you in advance !
(I know that nos is supérior, but well really like to know if there will be tubes available in the next decade :D )
Apr 24, 2017 at 2:07 PM Post #39,620 of 42,298
  Hello,
Get an adapter 6SN7>6DE7 there are all sorts of new production tubes. There are tube adapters out there for other tubes.  You'll never run out of tubes.  The market has a way of filling voids where there is an opportunity.
Apr 24, 2017 at 4:42 PM Post #39,623 of 42,298
  I just went back to the compatibility chart and you're right.  I'm surprised that Woo made the the WA6-SE with limited tube compatibility.
Unlucky the 6SN7  are'nt compatible with WA6SE
cu
I went back to the WA6 from the SE because I didn't realize this when I bought the SE.
Apr 24, 2017 at 4:45 PM Post #39,624 of 42,298
Hi,
I just read your post and I wanted to ask our opinion about Viablue vs. BDR spikes. Which one gave you better results? Did you find one would work better under a particular component than the other?
Many thanks!
Apr 25, 2017 at 1:10 AM Post #39,625 of 42,298
DeOxit does the job - just a little. Also be sure to give the pins a "rinse" with isopropyl alcohol afterwards to remove any junk. Apply with a cotton bud/swab.
Awesome. Which Deoxit though? Spray, wipes, tube of liquid? Can you shoot me a link to the specific product you use?
Apr 25, 2017 at 1:17 AM Post #39,626 of 42,298
Apr 25, 2017 at 1:46 AM Post #39,628 of 42,298
Apr 25, 2017 at 4:19 AM Post #39,629 of 42,298
It seems to be about power  capacity.
6DE7 and other : 0,9 A
6SN7 and other : 0,6A
I see some people doing that .... but well with an orhto I prefer to have more ouput power, am I wrong ?
Another question : does a tube need a "burn in" time ?
Regards,
