shapeshifter44
- Sep 10, 2016
By the way, how is Woo WDS-1?
Thanks
Thanks
Thanks
Looking for a balanced DAC for my WA22 with Sennheiser Hd800s. I usually listen to classical music.
For example: I know Schiit Gumby is a good choice, but it is not compatible with most CD transports/players (it would make extensively clicking sounds and even erase the first couple of seconds of each song in a CD).
Not sure what you mean by "extensively clicking" when playing CD's. There is a relay in the Gumby that you can hear click when the music changes resolution. If I play a song that is 16/44 and the next song is 24/96, there will be a click from the Gumby between them as it adjusts to the new rate. As CD's are always the same resolution, you shouldn't have any clicking at all.
I understand what @shapeshifter44 is referring to.
It is the muting relay on the Schiit DACs (except the Modi) that doesn't play well with some Cd players like my Sony CDP C-601/701ES models. When in pause/skip/fast forward mode the muting relay continuously opens/closes besides when switching between bit/kHz. It is most annoying.
Thanks for the heads up. The only thing I play in my Sony SCD 777ES are SACD's which I don't run through the Gumby so I haven't been aware of that particular problem. I'll plug the optical out from the Sony into the Gumby to play some CD's and see what I get.
Other members have other model Sony Cd players that have no issues with the muting relay, so it doesn't mean Schiit DAC's won't play well with all Sony Cd players…but unfortunately mine don't play well together with Schiit DSC's
Looking forward to seeing 20 years worth of tubes coming onto the market that a few months ago blew everything else away
I've noticed a lot of people on here always rave about how much better the shiny new toy is over the old toy. Maybe it's similar to a new girlfriend/boyfriend where they seem so much better than the old girlfriend/boyfriend, but a year later things aren't quite so rosy...
With headphone amps I tend to try and keep both around for a while, and it looks like Badas is going to do the same (be interested in your thoughts after a few months, but have to admit I'm already intrigued). I had a few headphone amps, but now I'm down to just two (both tubes). Adding a SS headphone amp could make for a nice addition, but I can't see myself not ever having a tube headphone amp.
I agree. Even tho to my ear the V281 SS amp is beating the Woo WA22 my WA22 is not going anywhere. Tubes are nostalgic.
I did more side by side listening last night. V281 beats WA22 in just about every sound aspect except mid-range. There is plenty of mid-range on the V281 however the WA22 just edges it.
Everything else like clean bass, clean treble, soundstage and I can't believe it holographics is better on the V281. It also has authority. It just sounds beefy. Like a boss. V281 is known as a "plays any HP amp" and you can hear it. It made my LCD-3's sound like something stronger like Abyss.
There is a reason some Woo members have moved to Violectric (3803Joe comes to mind (also a V281)). Violectric sounds like a beefed up Woo but without the hassle of tubes.
I plan to do 99.9% of my HP listening using the V281. Just those odd do nothing days I will use the WA22.
Probably why they are updating it.
Could you have a bad Schiit DAC?
Are you talking about the WA22 update?
I think the point here is tubes use to have certain advantages over SS. Like silky and holographic sound.
Not anymore. You get those tube advantages plus all the advantages of SS without the hassle of tubes.
Updating the tube amp won't bridge the gap.
