- Jun 15, 2012
Glass encased dog droppings would be a big improvement over stock tubes
Congratulations on entering the world of 300B tube rolling. Your ears will love it, your wallet will not
lol
Yeah, why do they do that?
With a bit of effort they could get reasonable NOS tubes for not much $$.
I cringe at the sight of their amps on display at trade shows with those stock tubes. They could be turning potential customers away.
Problem solved since that post - I had to pair the 6f86 with a glenn adapter. By which I mean there is a right a left on the 6f8g tube and also right and left on the adapter. I had the adapter in the right and left slot but the tube was configured - left in right and right in left.
So I fixed it ¬
right tube in right adapter in right socket - left tube in left adapter left socket
It was totally my own fault for not reading the message properly. All is good now and the combo sounds amazing!!!!
I have never heard about that. I have been using 6F8G tubes and Gelnn's adapters for years abd have never heard about specific tube and adapter per channel nor I have had a problem switching them around. Hummm
Glenn labeled mine left and right. He knew I wouldn't read his instructions.
He labelled mine as well - that was not the problem. There were numbers on the tubes that correlate to the left and right adapter - I needed to sort them in the right order and then fix the adapter to the left and right socket.
I had - right tube in left adapter/ left tube in right adapter
left adapter in left socket/ right adapter in right socket
you see where I went wrong?
Ummm, no, I don't. I don't understand what you mean by right and left tubes. The position of the adapter determines whether the wire will be to the outside or the inside so that makes sense but why would it make any difference which tube was in the adapter?
sweet mother of **** - just plugged the LCD3 in the WA5 with the new tubes!!! My god the sound!!!
Makes no sense to me either. Amps worth thousands of dollars with craptastic tubes in them. You are getting a very small fraction of the potential of these amps with the stock tubes.
Mid level Shuguangs are not that expensive and are decent performers - the HiFi series, for example. These are OK tubes, and a long way better than those horrid stock abominations.
Those stock tubes, especially the rectifiers and 300Bs, make me want to stuff my junk in a bacon slicer.
