Justin_Time
I have tried the HE6 from the adapter box using the WA5 and 845 SET amp - I prefer the K1K output in both cases. Sorry if my earlier posts didn't make that clear (English is my first and only language, but sometimes it is hard to tell).
For me, the WA5 K1K output beat the WA5 adapter box significantly. Hard to be specific, but I wasn't getting that visceral body to the sound as much with the adapter box and some of the dynamics seemed to suffer also.
The 845 SET with the adapter box was much closer to the K1K output, but I still prefer the K1K output.
I can only guess that the resistors in the adapter box meant that the HE6 was struggling to get all the juice it needed. It does take significantly more gain to get the same volume level via the adapter box than via the K1K output on the WA5. Perhaps wiring directly to the speaker posts would change that, but I'm not sure that is a good idea with a tube amp - not a risk I want to take when the K1K output does such a great job.
The 845 SET amp driving the modded HD800 via the adapter box is a revelation. I find myself drawn to it - wonderful sound without the weight of the modded HE6 on my head - the headphones really do disappear and you float away on the music. My modded HE6 is still the best performing headphone I have, but the 845 + HD800 rig comes close, with much better comfort. WA5 + HD800 via the adapter box is no slouch either.
Very happy with the outcome as my HD800 was a little unloved before trying it via the adapter box. Now I have huge respect for it.
English ismy third language, so I can always use that as a crutch--or was excuse the word I was looking for?
The HE box use a 10-ohm resistor in parallel (to protect the tube amps, mostly). It uses a resistor in series as well to reduce the output to the HP--in my HE box, it measured 24 ohms. This may be what reduced the gain in your experience. You can easily replace that with a lower-value resistor.
J_T
