Badas
- Jul 9, 2014
You might be missing out, depending on your gear. My Vega DAC has an excellent USB implementation that, to my ears, sounds noticeably better than SPDIF (via co-ax or toslink - doesn't matter).
The USB is asynchronous, allowing the Vega to do it's magic in it's own time with the femto clocks and other goodies packed under the hood - result - audibly better sound. At least, that is my understanding - could be wrong in the details - don't care really - what matters is the sound, and for the Vega and my ears, USB trumps SPDIF everytime.
I'd suggest you try both SPDIF and USB on your gear and let your ears decide.
Not wanting to add more fuel to the cable debate, but I have tried a 1m $300 audiophile USB cable and a 5m $10 USB cable - and I can't hear a difference at all. No difference in drop outs or SQ or anything else using the Vega in 'Exact' clock mode. I believe what I can hear - and fancy USB cables don't make the cut.
So would I just go from my Arcam DrDock to my Oppo? I don't use a computer.
Edit: I just remembered I can't do that. The USB is a power supply on the Arcam Dock.
