Dubstep Girl
Which Cavalli? Which one?
Liquid Glass? Oooooooooo...
and Lightning.
The 596 pairs I have are matched, I purchased 40 596s to get 4 matched. The seller just tested it and label the box for me.
I think DG ruled out WA5 is the dual rectifier requirements, she has plenty of single rectifiers and if she is getting a WA5 she either have to sell all the single rectifiers or purchase more to get them in pair. Either way will be extremely expensive.
As matched tubes rectifier or not, if it is 5-10% off we probably can't tell a differences but once it is 10+%, I bet my money we can start tell tonal imbalance.
How do you define "matched" and how can you measure it?
Tube tester, my friend has one.
A tube tester only tests certain characteristics of a tube but it cannot tell you if they are truly matched. They do not measure the tube under the conditions that they are in when you are actually using them. If someone tells you that they can match tubes with a tester they are BSing you. I have 3 testers but I don't have the ability to "match" tubes.
Damn, more stuff to buy after the GSX-MKII
Oh well, I'm in the market for a longer balanced cable anyhow for the LCD3s; the stock cables a few inches to short for my setup....
Anyone got any suggestions beside Moon Audio's silver dragon?.... I'm hoping to keep it <$200 (I know, I'm a dreamer)....
Check these out--
http://toxic-cables.co.uk
Outstanding hand built cable at a great price (though not under your $200)
Matched Rectifiers in the WA-5
The rectifiers in the WA-5 should be from the same lot. Woo has the 5U4 heaters in series and have to have matched heaters
or one will have a early failure. 5U4s are not meant to be run in series. This is why I came up with the 596 they have matched heaters.
I even made a tester to test for matched heaters when I was selling them with adapters.
You can go back in this forum and look at the problems Dannie01 had with rectifiers blowing up in the WA-5.
Came up with the 596 specifically for the WA-5 but everyone started using them on other amps they are a good military grade rectifier.
DG will have to sell all the rectifiers unless she has them in pairs ore they will be blowing up in the WA-5.
