moriez
Since a week I'm the owner of a used WA3 and now in need of some brainstorming from you guys. Unfortunately the amp hums lightly but too audible coming from the transformer (powered up doing nothing / source unplugged). Bear with me before you say it's normal for tube amps. I've found that the transformer hum vanishes when I unscrew and take off the ''hatch'' which covers the transformer. When I lay back the hatch the hum is back (with or without putting the screws back in). The enclosure looks flawless to me. No obvious problems to be seen. Any ideas what's going on and how to solve this?
Second issue is a hum in the right channel over different types of headphones. It's volume independent and already switched the left tube for right. Source unplugged and tried another AC outlet.
How likely is this a tube problem and if so, how can I know if it's the power tube or drivers?
