juan1894
- Aug 29, 2012
The HD 439 has more bass than HD 429 too xP
I always like Sennheiser and already have a HD650 which I love but I am also looking for closed CAN in the Sennheiser range that design for HiFi not on the go purpose. The HD280/380 Pro are design for studio so I suppose they are less fun.
The 2 series are not over the hear except HD201 which I love too. 4 series seems to aim for on to go?
What choice do I have unless I pick the 4 series.
That's the thing with the 439, It really doesn't have enough Air to really shine. It will distort. The answer to this believe it or not, is to do the Bass mod. The same one used for the HD428. I recommend just opening one hole in the " Tape" more then one is overkill IMO. With one hole open it makes the Bass hit harder and it's tighter as well. Also this all but removes the problem with distortion.
It allows the drivers to get rid of the extra pressure from inside the back driver housing. It really makes the drivers have more room to Breathe.
You can see in this pic, there is a black piece of tape on the driver housing. Under the tape is ports (Three holes) You can use a sharp tip of a pen or something to locate the center whole. Then use a exacto knife and gently score out the tape between holes 2 & 3. Then just pull out the little center piece exposing the center hole. Put everything back together and you are good to go.
This is very simple and even someone without major skills can do this mod. Makes a big difference!!
