Revisited the dampening in my YH3s tonight as I'm not happy with their sound now that I have the YH100s so far along. I kept the tape on the driver as it was and went with a full diameter Moorbrook felt disc held in the center rivet by blu-tak. For the cup I used b-t in the dimple at the back instead of cotton. Covered that with a piece of muslin to keep the FG out of the b-t. Then I replicated the Tomek EGGS with cotton quilting batting cut to be size of the cup with the centers cut out to a diameter equal to the diameter of the driver's holes. The center was slightly over filled with FG. Then a final cover of muslin to protect the felt on the driver from the FG.
Yeah! Getting so, so close to the perfect scheme! They are just overdamped a bit, but the mids and highs are addicting this way, so I may just leave the bulk as it is and only trim the bottom most layer of batting to open the vents a touch and trim the upper most batting layer in too, to remove a little dampening and allow a little more sound or air to get out the vents with the two middle layers a touch wider to offer resistance from front to back and out the vents.
The new scheme did drastically improve the soundstage though. Still not as open as the YH100s, but better than my stock ESW9s now, which it wasn't before. Haven't compared it to the K141 as that's probably the closest dynamic can I have.
I think that if I can just open the sound stage and shave a hair off the dampening to bring the bass up just [size=xx-small]that[/size] much it will be perfect for the MHM amp with 12AE6a tubes.
I compared it to the YH100s and they both have nearly identical mids, so I'm happy with the materials and tape on the drivers. Now I just need to take advantage of the YH100s larger driver for more bass and damp the 100s with more cotton and remove the felt from the vents and just have the batting discs go right to the edge without being pressed into it. That should open the soundstage on the 100s and the extra cotton should add the dampening I need.
Since pics of these drivers naked in their dampening beds could be considered Ortho p@rn and unsuitable for impressionable minds, I'm setting up a pay access website to supplement my income in the tough economic times. Team Ortho members will receive access for less than a dollar a day!
