Fostex T10
- the best stock vintage ortho
- its just not spectacular in any way, vanilla .... Outside of being remarkably flat. I guess besides that its biggest strength is being inoffensive.
- I've never reached for this headphone. However, the two I've owned have been in bleh condition. The first one had terribly worn pads that made it uncomfortable to wear. And this set has a messed up cable that makes it a pain to use. So, if they were in better condition then ya I might use. But in this case these are for donation pile.
- my fpc tends to measure things as a little less bassy compared to my EARS, its the compensation curve, but which is more correct - idunno.
Im going through and measuring my headphones on my rebuilt flat plate coupler rig to compare to the first iteration of this rig. This v2 tends to show a little less highs than previously. One cause for this difference could simply be in the position of the mic's depth in the coupler... I've experimented with different depths +- and result was highs are mainly and majorly effected even with just a difference of 1-2mm.
Before I move onto to the next headphone I will have a quick listen and maybe add some new subjectives from my current perspective.
