See if you can try this arrangement.
https://www.head-fi.org/threads/orthodynamic-roundup.111193/post-13995265
SCROLL DOWN 2 POSTS FOR IMAGE, and further along for some thoughts by others as well
It may cost a tiny bit for a 3 x 3 inch piece of Sorbothane, but results are well worth it.
Very transformative and nothing else I tried got similar results.
I do have yet to trial some of that fo.Q damping tape, I do have the TA-32 and TA102 thicknesses but it is
uber pricy and the T10 here is already tweaked..
I don't care what gets used so long as results are audible and an improvement.
I am not a materials snob = If I can find something better I will use it and switch at the drop of a hat.
So far trial with fo.Q Damping Tape on a dynamic has a
slightly different characteristic effect than sorbothane ( yet to try fo.Q on an ortho )
There were a couple others here who also did this to a T10 with happy results, or at least something extremely similar.
It's nice to get feedback on things.
Best thing to do is let that driver fly free without being stifled directly at the rear face of it.
Give it some room to breath or at least use a material that can breathe a bit while reflecting just enough of the sound back to boost these black nameplate ones.
= It is the Sorb itself that will give the main charateristic results so you can't really duplicate that with other stuff.
One other thing to consider is something
leeperry always mentions, and that is the age and/or condition of the older copper in their cables.
Some things do benefit from a new cable install.
Perhaps as a final tweak. Or leave as-is it may be just fine.
Hope this helps in some way.
Don't get frustrated, it is all supposed to be fun ( I think )
~Nick
P.S.
@JadeEast is right about the amount of first aid papertape ( commonly referred to as micropore in here ).
It is too close, and is reflecting too much back.
When I was stupidly obsessing over a T50RP Mk2 mod even a tiny shift around of a shaped piece of that tape , or adding a small square extra tended to affect the sound.
I trialled so many tuning pads with variations of that papertape / micropore I nearly went nuts.
Luckily it is now much improved compared to the last posted mod scheme, some real bass now.
Long story short the stuff does affect things noticably when on backside of a porous, direct damper pad like you have there and I also used.
( hear that
@waynes world ? Better send yours down for the update or else...)
