May 30, 2013 at 2:55 AM Post #21,691 of 27,295
Are electrets allowed?
That's some thin ice you're standing on
May 30, 2013 at 6:44 AM Post #21,692 of 27,295
Got an ATH-6 a few days ago. It's on its way to me.
Doesn't have the energizer but I got it for absolutely dirt cheap ($18) and its in decent shape. Anyone have any experience with it? Maybe have a spare energizer or stat amp they'd be willing to sell?
I have the ATH-7, one of my favorite phones. If I recall correctly, the ATH-6 and ATH-7 headsets are identical, and the difference is in the quality of the transformer unit.
Those units have an idiosyncratic oversized DIN-like plug (or maybe like a Stax Pro plug with a pin missing and a locking tab)... not sure how easily they'll adapt to stat energizers, or even if they're electrically compatible.
There are a couple threads in the head-fi archives about Audio-Technica electrets, but they haven't been popular enough for a community of hobbyist hackers/reverse engineers to form.
May 30, 2013 at 1:50 PM Post #21,693 of 27,295
Yeah the AHT-6 and 7 are identical.
I was planning on rewiring the headphones with a Stax plug, and actually since the bias voltage is built into the electret transducers any electrostatic energizer should work.
May 30, 2013 at 2:08 PM Post #21,694 of 27,295
Im selling a ATH-7 with energizer, boxed and in good condition. Maybe not exactly what you were looking for, but check my signature.
May 30, 2013 at 10:10 PM Post #21,695 of 27,295
I'll push the envelope some more... it's still a planar transducer
Here's my modded Pioneer SE-500, One of the three piezoelectric headphones Pioneer made back in the 70's.
What I did was open up the cups and convert them to closed back by striping electrical tape along the inside of the earcup.
Additionally, I added little pads of velcro on the yokes to hold the cups in place. This prevents them from "winging out" when you put them on, which was preventing proper fit and looked pretty damn stupid on your head.
In stock form, these headphones are downright terrible, incredibly muddy low end and no highs at all. Ruler-flat presentation and uninteresting. The modifications I performed get rid of ALL the bass bloom and bring the treble forward a lot. It becomes bright, but a completely different bright than anything I've ever heard. It sounds lush, sparkly, and incredibly musical. I'd almost call it a cool, wet sound. The drivers are capable of a great amount of detail and the mods really bring it forward. The imaging is wonderfully precise and there's even a bit of soundstage presence on these even though there's less than 1/8" between the back of the driver and the earcup.
Probably the most incredible transformation I've ever heard from a headphone. If anyone who owns this headphone found it underwhelming... do the closed back mod. It's a completely different headphone.
May 30, 2013 at 10:49 PM Post #21,696 of 27,295
In stock form, these headphones are downright terrible, incredibly muddy low end and no highs at all. Ruler-flat presentation and uninteresting. The modifications I performed get rid of ALL the bass bloom and brings the treble forward a lot. It becomes bright, but a completely different bright than anything I've ever heard. It sounds lush, sparkly, and incredibly musical. I'd almost call it a cool, wet sound. The drivers are capable of a great amount of detail and the mods really bring it forward. The imaging is wonderfully precise and there's even a bit of soundstage presence on these even though there's less than 1/8" between the back of the driver and the earcup.
I've got the 500 and agree with your impressions. I'll give it a try. Also have a 700 that's a little better but still Meh.
May 30, 2013 at 10:54 PM Post #21,697 of 27,295
The SE-700 improves in the same way as the SE-500 when converted to closed back, but the end result is less trebley and more balanced. It also has a slightly different presentation than the 500 and is a little bit less detailed as well, but that would likely improve with better amping (which I can't provide at the moment).
However, the modification is a bit more complex as you have to take off the inner rings and meshes to put the tape on; putting it on the inside mucks things up for some reason. Be careful if you want to try it on the 700, and be sure to have some superglue handy. Once those inner rings come off they really do not seem to like staying in place anymore.
May 30, 2013 at 11:11 PM Post #21,698 of 27,295
The SE-700 improves in the same way as the SE-500 when converted to closed back, but the end result is less trebley and more balanced. It's a little bit less detailed as well but that would likely improve with better amping (which I can't provide at the moment).
However, the modification is a bit more complex as you have to take off the inner rings and meshes to put the tape on; putting it on the inside mucks things up for some reason. Be careful if you want to try it on the 700, and be sure to have some superglue handy...
Thanks for the tips. I'll probably do the 500 first since it's easier, and see how it sounds.
Planning a TDS-15 transplant in a Takstar HI-2050 foster fone. The TDS headband is broken so might as well give it a go. Any advice is appreciated.
May 30, 2013 at 11:19 PM Post #21,699 of 27,295
did either of you try running them directly off speaker taps? If I recall correctly that is a possibility for giving them what they need, but I may be wrong
May 30, 2013 at 11:26 PM Post #21,700 of 27,295
Yes. I bought a Pioneer switching box that connects to the speaker taps of my McIntosh MC-402. I was under-whelmed. Probably should re-visit it.
May 30, 2013 at 11:57 PM Post #21,701 of 27,295
My SE-500 and SE-700 sound infinitely better out of my desktop system's speaker taps, but theres an internal splitter that sends everything 60Hz and below to the subwoofer, so its not exactly usable.
I plan on getting a speaker amp for them soon.
Also, flyer, I wouldn't use that old junction box, it muddles things up. The resistor network in it is old and bad. I myself just made a little adapter to plug into from some spare parts. Works like a charm.
I'd take a picture but it's late and the lighting sucks right now, lol.
May 31, 2013 at 12:25 AM Post #21,702 of 27,295
^ BMF if it is that same one I am thinking it was NOS junction box right?  Depending on the resistors type inside you could always open it up and replace them with something "tweaky" might be a fun quick project. Be interesting to see the values anyhow and how they set it up...thinking out loud again.
Takato what did you use?
May 31, 2013 at 12:28 AM Post #21,703 of 27,295
I used an old 1/4" adapter from a karaoke machine and some speaker wires from ratshack cut relatively short. The plug sits on top of my woofer.
Nothing too fancy, but it gets the job done.
May 31, 2013 at 12:40 AM Post #21,704 of 27,295
ahh no resistors at all i see . No doubt the best method. Our "Ratshack" became "The Source"  Somehow it's just not the same as the old days.
May 31, 2013 at 12:49 AM Post #21,705 of 27,295
Yeah, the only benefit that resistors offer is slightly more protection against an accidental overvolting, but I don't really have to worry about that since I'm careful with it.
Not to mention that my desktop speakers couldn't blow the SE-700 even if they tried, hah.
