Sep 13, 2012 at 11:58 PM Post #20,461 of 27,308
got any pictures of the shell?  you liking the sound?  congratulations on the transplant!!
Sep 14, 2012 at 3:19 PM Post #20,462 of 27,308
Well the shell is the HP-2 shell that I had lying around after using it's driver.
Sound is not bad, I feel like the lower-midrange is a little bit higher, making the vocals and overall sound a bit warmer but stuffier... but not a bad sounding phone per say!
I saw you mention using neoprene as a spacer, and thought I'd try with whatever I had in hand... the cork sheet I had worked plenty, even with the short screws of the Yamaha's. Thanks for the spacer idea nick!
As for the driver issue I have, it's not as bad now because the baffle clamps the drivers pretty hard against the back of the cup, where the hinge is elevated. Whenever I occasionally lose the right channel, I just press against it and it's back!
Sep 15, 2012 at 1:19 PM Post #20,463 of 27,308
Well, the Unipolars seem to work fine out of the SU-300, no overheating or nothing; no issues came up in about 30 minutes of playing. Maybe the SU-300 simply prefers taking in regular headphones through its frontal section rather than the bottom.
Sep 16, 2012 at 12:54 AM Post #20,465 of 27,308
The Unipolars WORK? Boy, that sure is a slap in the face to anyone who warns people against buying electret headphones.
shhhh.
you forgot you read this post, you forgot you read uhhhh what .
Sep 16, 2012 at 10:03 AM Post #20,466 of 27,308
Don't worry, they do have some channel imbalance in the bass. Nothing a few ortho modding methods couldn't mitigate, at least for now.
The sound overall is definitely something to EQ - without it, they're dominated by a bright and unnatural-sounding treble. That non-EQd response is relatively neutral between 80 and 2500 Hz or so, but the problems are beyond that: some extra brightness at 3 kHz, about 10 dB sucked out between 5 and 7 kHz, about 5 dB extra at 7-11 kHz, and the bass only extends down to about 80 Hz before slowly fading off (though it's still within 5 dB of 1 kHz at 60 Hz). The upper mids and treble aren't too hard to fix with EQ and the phones seem to take it ok-ish.
With that sort of corrective upper-end EQ, the treble is listenable, the mids are natural if a bit withdrawn - and some bass exists, in neither a negative nor positive way. Soundstage is ok, though I've not given them enough time to say too much past that. There's some amount of detail, but not massively - I think about the same as what the HP-50S does, which isn't bad. The overall sound is somewhat responsive but at the same time somewhat laid back.
Sep 16, 2012 at 6:39 PM Post #20,468 of 27,308
shhhh.
Oo, right. Yeah. Electrets, they straightup without merit, man.
Glad to hear they have some promise. Still, you were brave to buy them, since they're the poster child for electret failure. The bass-only channel imbalance is probably a blown earpad or some other leak. If the mids and highs are okay, chances are the electrets are okay. Keep us posted. Any idea of when these were made?
Sep 16, 2012 at 10:36 PM Post #20,469 of 27,308
This specific pair, you mean? No. For some reason I have the year 1977 in my head for the Unipolar 2000. There's that review from Gramophone magazine on Google that's dated 1978, so late '70s is likely.
Our MDR30 owns (or used to own?) two pairs of Unipolar and went as far as this to find a replacement driver - I'm surprised he hasn't said anything about the sound.
Sep 18, 2012 at 6:12 PM Post #20,474 of 27,308
whoa!!!!!!!!!!!!!!!!!!!!!
I know of a couple other names these go under also... not saying until I secure a pair. Absolutely excellent find!
