Latest project is complete.
Take two 32 ohm SFI's khbaur was generous enough to sell me a while ago, one vintage minty classy looking ( IMHO ) Grundig 211-A from ~1968/9, stir in one pile of coffee and a night of modding.
Gradually add Newplast and rest of ingredients. Bring temper and frustrations to a boil and then lower heat and cool off,
Enjoy.
Serves one generously.
Here we have it. This is a very interesting donor can. It's earcups use absolutely no screws yet seal up very tight. They are made from a sturdy yet pliable rubbery plastic. All you need to do is twist out the seam along the baffle and the baffles pop right out.
Other than the tiny extra bass hole I drilled in the cups this is completely reversible. A very surprising Grundig driver if it was to go below 30 hz I would have kept it stock no question. Onthe hunt for one of their other model for a keeper. The particular one is rather ugly but should be fantastic if I can find a mint one.
Different damping scheme used here. Time will tell but nice so far. Very
unclosed sounding. Super detailed so far, treble is up but non-fatiguing, a
very slight drop to that will be perfect. I bet this is due to some slight compression against the rear cupspace around the foam disc edges. A quick fix.
Stock 1/8 nicely hidden and moulded bass ports below the cable entry but I made two new ones also I think maybe the same size.
I took a ring of the thin 1/8 inch Creatology adhesive foam and stuck it to the driver rear, leaving the center opening so i could fill that area with a disc of the Arctic Bamboo felty fabric ( half cotton half bamboo fibres ). I find this stuff adds a great sense of depth to things YMMV ( like an superultra gauze with built in semi-damping ). The drivers were missing their stock dust guard fabrics so i replaced them prior to doing all this.
In order to still dampen this SFI up a bit beyond that Arctic bamboo disc, I topped this layer off with a disc of Acousti 3 layer foam that only has the adhesive on the outer edges to match up to the red Creatology foam and let the sound go through the middle.
It sort of could be seen as a sealed chambered damping stack. Sort of.
Secured drivers to baffles which came from another donor can. Cut and filed them down to shape.I used red ( right ) and blue ( left ) Newplast to secure those. Each baffle side after weighed out @ 55.1 grams. Extra space inside around the driver filled with an acoustic filler. Cup rears covered in Creatology adhesive foam.
Added 2 strips of Akasa topped with some actual foam on the headband for comfort.
Will whip up a leather thing sometime later.
Donor baffle below is shown with outer ear side up. Driver protrudes a few mm higher than the baffle level, not much. You can find similar easy to mod baffles like this in many Koss cans.
I thought I had learned my lesson about drilling holes from outside inwards from screwing up the first Alder pair way back. I guess not.
After fixing these and opening them back up I saw the drill bit tip had swirled up almost all the acoustic filler essentially making it useless so that's all replaced . Also rounded off the outer edges of Acousti foam damping pads. A bit of acoustic filler directly behind the driver now also in the very rear.
Taped off the baffle/cup seam just to be sure.
This is the way they should sound now. Very good sense of depth/dimensionality. Good bass. No treble fatigue.
DAMPING UPDATE
Determined bass levels could be brought up a touch, so in I went again to make this a version of the "double-stack" Acoustifoam damping like I have in the Dead Rebel mod. Previous damping kept intact but added a second 3 layer tapered cap to the top.
Also
-Reduced the acoustic filler down to half
-Opened up the extra bass port to 7/32 in. in addition to the preexisting stock one that is1/8 inch.
Picture below shows new top damping pad ( secured with it's intact outer ring of adhesive, center is clear of adhesive backing like the one below it.)
Not shown is the acoustic filler that gets added. That's tohp sekrit
I can discern every single nuance in the music however subtle. Beautiful. Sensitivity is dropped down though, guess i need to look into a newer portable amp that puts out 200mw plus. E5 isn't cutting it now even after the 76mw of the Cowon
