vid
- Jan 5, 2005
Some more EQ experiments. I found that the foo_dsp_xgeq plugin for foobar does separate left/right equalizing, and since it seemed to produce a smooth curve (unlike the curiously angular default foobar EQ), I tried it as a replacement for physical mods on the trusty HP-50S.
Left picture is for the left channel, right for right. The volume was adjusted so that both channels measured as having about equal amplitude.
The resulting curves. Blue and red are the equalized channels, grey is what I used as the target curve - the physically modded left channel. I toned down the 3 kHz peak a little. These graphs show ear canal resonances only; raw data; not to be taken as full-fledged frequency measurements.
The idea was to get rid of all mods and instead use EQ to push away the ortho bass hump (by making use of the real-world frequency graph from physical hump-moddings); as putting anything inside the -50S cups seems to turn into a horribly compressed pile its decent soundstage unmodded.
The results... Hmm. Hard to say. It sounds good with this EQ, but I'm not sure if it's not a little bit harsher-sounding than the physically modded version. I'm not sure, but not by much in any case. The soundstage is much better in this unmodded way. The ~12 kHz hump needs to go though - it was in the original modded version as well, and it's too loud.
