wualta
Orthodynamic Supremus
- Sep 12, 2004
Or lay in a supply of silica gel packets.
At that point you might as well start crafting cups out of aluminum. Either way, still not a great solution unless it's cold outside, in which case it might just have the opposite effect and make your ears too cold.
The best solution still remains the simplest. Air out your ears for a few seconds every couple songs.
Originally Posted by kalbee /img/forum/go_quote.gif
Don't silica gel packets heat up with moisture?
hey guys, any idea how thick or thin is the hp-1 driver? thanks
Roughly 7mm. If you need it more exact than that, let me know.
Great to have some charts to look at. Anyone have an idea as to the cause of the 3k peak and ridge?
