khbaur330162
Vintage Ortho Ninja 🥷
- Aug 5, 2006
I gave my pair away to a friend so I'm afraid I can't supply pictures except the ones that I took the day I modded my first pair a few years ago. I'm guessing you saw the original post I made?
In the picture where you see the sticky tac around the drivers you also see the damped vents above and below. You have to seal those up which I failed to do in initial mods.
As for pads, apart from turning inside out, I just modded the stock pair in order to try and get some extra bass out of them. It closes up the sound considerably, though, so unless you're ok with that I wouldn't recommend it. They sound fine to my ears after simply reversing the pads. Once doing this they're a bit more compact and your ears are very close to the drivers. I never had an issue with just throwing them on my head. The leather pads I stitched for them didn't sound as good as stock. I sourced the leather from an out of commission couch and it was pretty thick stuff.
The SFI drivers are a perfect fit. I ended up filing down the little tabs that keep the drivers from falling through the baffles in order to mount them flush. Gets the drivers another mm closer, or so. If you plan on the CD380 housing being their new home I'd use epoxy putty to mount and seal everything.
I don't think sealing the baffle to the housing is necessary in this case. You won't be able to do anything about backwave unless serious modifications were in order which I don't recommend or see as necessary.
Interested to hear your report and see what else you can do with them. They are very sturdy cans and I loved them as knock-arounds or even for the occasional critical listening session. They're SFI's, so of course the detail is there. I've thought about another CD380, or even CD280 as it looks near identical, to mod up another pair. I recently slapped those same ATH-2 drivers you see in the pictures into a Sony wraparound frame. Not bad at all, but after a few hours my ears are hurting. I miss the SFI-380, tbh. Probably the perfect compromise between SQ and money, imo. $20 for the drivers, $20 for the frame, 2 hours of modification and you're done... for life. Run. Run away from this place and never return.
Meh. I decided to mod my cans real quick and see for myself. Hope you guys like this one, 'cause it was fun to do.
Started out with stock Sony MDR-CD380:
http://ecx.images-amazon.com/images/...RL._AA280_.jpg
Opened them up and stuck the ATH-2 drivers inside with a bit of wall tak:
http://i8.photobucket.com/albums/a5/...2/IMG_3366.jpg
Took the damping material from previous enclosure and put it into place:
http://i8.photobucket.com/albums/a5/...2/IMG_3368.jpg
http://i8.photobucket.com/albums/a5/...2/IMG_3369.jpg
Stuck the baffle back onto the headband (notice how the damping material is now stuck into place *thumbs up!*):
http://i8.photobucket.com/albums/a5/...2/IMG_3370.jpg
http://i8.photobucket.com/albums/a5/...2/IMG_3371.jpg
Screwed it all together:
http://i8.photobucket.com/albums/a5/...2/IMG_3376.jpg
Stock pads are cloth and probably not suited for ortho's:
http://i8.photobucket.com/albums/a5/...2/IMG_3377.jpg
Unless... (they're pulled inside out and stuck on the opposite driver housing):
http://i8.photobucket.com/albums/a5/...2/IMG_3381.jpg
Finished product:
http://i8.photobucket.com/albums/a5/...2/IMG_3384.jpg
Sound?:
I need to spend more time with them. I literally just did this mod so have had little to no time to even audition them. From what I hear, they sound possibly a little muffled, but honestly, pretty darn good! I'll have to let the Beta22 warm up so I can do some real listening. And it's yet to be determined if this accomplishes what I set out for it to do; increase soundstage.
