maverickronin
- Apr 5, 2010
I haven't ordered the memory foam yet, but this is the site I found.
It should conform to my head pretty well so there won't be any air gaps but if the outer covering of pad is porous then some of the pressure will leak through anyway. I don't know how much or if it will make a difference in bass response but I'm not in the mood to spend 3 or 4 straight days sewing several different pairs of pads made from expensive materials to find out if sealing it with the plastidip does make a difference or not. I'd rather go overkill with the planning beforehand because its much less tedious.
True. Come to think of it you're using memory foam... A) Where'd you get this? B) Isn't that going to seal pretty well all by itself?
And, randomly, on the topic of pads and that article on innerfidelity. The article talked about bass dips due to clamping force/squishiness of pads. Call me crazy, but the pad vibration often gives the bass an insane "This is intense bass" feeling which can't be measured by the dummy head. You could probably eq bass heavily sub 70-80Hz and replace with vibrators inside the pads. I wouldn't do it, but how many people off the street would even notice? I'm not saying this has an application in any way shape or form really, but interesting to think about in terms of measuring a headphone, getting back to the original article. And this is also one of the reasons I think mass loading the baffle can have a positive effect on the sound.
