"good" silver epoxy costs more than $30, the cheap stuff doesn't have the best reputation. Even carbon conductive glue has a better reputation than cheap silver epoxy. don't exactly know about the distortion caused by different types of conductive glues, but i hope it isn't too much. I think that the carbon glue probably isn't that different than the mix they use for carbon resistors, and it's only about 5 bucks.
Thanks I will drop by the big bad electronics store tomorrow and pick up some of that. It seems it's using aluminum solder so the old school roll of leaded stuff just falls off and I don't want to risk messing up the membrane If I haven't already. Plays just fine may have shortened the lifespan of it who knows.
http://www.mgchemicals.com/products/8331.html
That's the stuff I bought. Forget where I got it and how much I paid. It's been quite a while.
Yeah good old MG Chemicals. The place I'm going will have that for sure then. Excellent!
Making changes to half of the damping scheme in the open back Pioneer SFI's. Showing promise now with a substantial change in sound. Will update as necessary for those that may have an inkling of interest. ( what exactly IS an "
inkling" anyhow where did that expression come from )
Update: breaking news , results just in.
Somebody call the mayor!
I will from this point not ever use felt direct damping on drivers again, and will be going back to retrofit the other pairs I have done that to if it's applicable given the cup space, don't see why not.
I do not feel it is necessary to have to put a felt layer ( disc or donut ) to damp the driver, bring up details, and/or increase highs. This has the sort of teete-rtotter/see-saw effect depending on the felt used i found: sacrifice a bit of bass using a felt disc/donut for a slight bit of treble and driver response. Well at least this isn't necessary for increasing details as I am experiencing, so the bass can fly free and still gets tightened up and the driver seems to have tightened up as well from what I can tell. ( phew longwinded and confusing maybe I could have said that simpler )
How's this : if I want to keep treble and keep bass and still have a damping for the driver, and clean up the sound at the same time , from what I have gotten so far this is my tool. You may want a bit of beyond-the-driver vent damping to bring up the internal air pressure so it'll be a case by case thing and I would expect the same variable of housing size, open or closed, optimal venting to have similar effects as before.
Direct damping on both the HOK80v1 and the SFI open-back Pioneer LOOP pairs is accomplished using , yeah I know
Acousti 3 layer.Sold as "Acoustipack Extra" in single 17x18 inch sheets. But honest that horse liked being hit, and now it can be freed and live peacefully roaming vast meadows for the remainder of it's existence.
This latest thing : for the Pioneer LOOPS I removed the felt driver damping donut and cotton filler, replacing it with a disc of Acousti directly pressed to the back of the driver, behind that at the back of the cups is a disc of thin dense black felt from Rhythmdevils, and right against the outer mesh is some of that transparentish thin black fabricy stuff that's sort of like the landscape cloth you can buy but thinner. I put the denser black felt disc in there in the back to increase the air pressure that the driver has to push after it gets past the Acousti so it bumps up the bass, which from trials it actually does, while not reflecting too much back which happened when I used a double felt disc trial. It's a fine line.
The foam cannot be pressed too tightly against the back of the driver as it will cause a treble/upper mids rise. Just tight enough not to compress the outer foam layer too much and let it function as it was designed.
( had to carefully strip off the adhesive backing with an extended exacto utility knife, to do this I stuck it to the table and slowly sliced like bread as I pulled upwards) otherwise I'd be installing a jumbo reflex disc of sorts and no sound passthrough would occur. That's fine and preferrable of course if you are using a shallow cup and it's mounted directly to the rear of the cup. ( using it the normal way )
This stuff is giving me the exact same qualities as it has with the HOK 80.
Let's see if I can describe it without making a complete audiophool of myself, in a number of random sentences that will probably talk around the experience.( on these Pioneers )
* I can listen
at any volume without the slightest fatigue as happened before.
* Even the slightest detail is noticeable without any traces of resonance.
* This is
not because it's now "dark" or "less bright"
* Instrument placement seems improved for whatever reason, more dimensionality. This also happened with the very small enclosed HOK 80
* Instruments have realistic body or voluminous qualities now, as though it has been expanded in nature. Tones of the instruments are awesome.
* Every instrument is discernably separate without sounding artificial in any way
* Clean sound ( no booming or muddiness ), could be described as "organic" I guess.
* The music is more a feeling experience rather than a hearing experience.( that may make no sense I'm just putting that out there )
* Clangtint. Lots and lots of Clangtint. hahah a.k.a.Timbre. Funny description from wikipedia on that:"Timbre has been called a "wastebasket" attribute (Dixon Ward 1965, 55) or category (Tobias 1970, 409), or "the psychoacoustician's multidimensional waste-basket category for everything that cannot be labeled pitch or loudness"
This sound is so organically bodied and revealing without any resonance whatsoever to my ears.
Completely, entirely different sounding compared to before ( of a higher quality ), I do not know how to adequately convey that. If you can think of any way I can clarify anything please ask. They disappear and I get right into the music now, without thinking about future mods while I'm wearing them.
You're
possibly going to lose some sensitivity here for driving them. Who cares.
Apologies for the descriptions I find it difficult to explain using the common terminologies.
Hope I didn't bore you just HAD to mention what this does. YMMV, FWIW, etc
