nice thanks! Are you using the yellow shammy (I can't be bothered to try to spell that word) as well? Or just the 2 small circles of different density felt in the middle, with nothing on the edges of the driver?
yellow biscuit are the most favorite material other than rockwool or any other felt/foam, i use the stock biscuit in the centre of sandwich schemes..the white dense felt i think was the oz felt that came from ludoo, the black thin felt are from yammy..the (broken) white disc for the open area of the cup are 2 layer of soft care (wet) wipes that used to clean baby or dirt..
The yellow is the stock biscuit.
How do the Koss pads sound compared to the stock pads? The stock pads are pretty awful, so I'm assuming there was an improvement with even more bass, but how do they effect the mids through highs?
i like this MV1 pads, its add more comfy..i like how it look on my NAD&i can use it without being tired after using it for hours..i think i dont need another pads cos i like this pads better than the stock pads..
for the SQ wise, it's change a lil' bit of the bass presentation and add some depth but not add more quantity, now the bass are thinner but good quality with it..the high become more extend with this, so its sound more stats-alike than using stock flat thin pads..the staging are improve as well, maybe because of the "spacer" that made like a dome between inner holes (which is bigger diametre than the stock one) and angled ring on the outside edge of the pads..midrange became more thinner (not much but noticable) as the midbass more tight now..i would try to roll the schemes inside to stock factory damping (with just 2 layer of yellow mineral wool) and share the result later..
i hope this time i didn't confuse all of you guys with my bad english since english aren't my native language, not to mention i post this mobile with opera on my iphone 3G..strange, using Safari on iphone can't post any reply on head-fi at all..
edit:
i guess just a bandwidth problem cos this forum engine not too friendly with mobile browser..
anyway i had try to remove the middle circle felt&2 layer of tissues/wipes, the result the bass quantity coming back again and trade-off a lil' bit high extension..more efficiency than before but became more loose..
so i try to put back 2 layer of tissues disc, and found not much but impact are added but still loose on the overall sounding..i remove again the tissues and place the 2 felt of different density and found the bass still thick&got high extension as stats-alike but sound more natural, not harsh or heard metallic..OK, that's for now..
