Hi all
Today I did some mod to the fostex T40v1. I found some important things during my mod.
The air volume at the back of the driver players an important rule. Especially for the bass response. Right now my T40V1 would not make you think it is bass-shy. It has some real good bass depth. And the increased bass dramatically improved the warmness of the sound signature.
I tuned the bass response by drilling a small hole at the top of the earcup. I will attach picture later on how I drill the hold and how does it work to tune the bass.
In side the earcup, there is nothing. I only cut a small cylinder of small open cell foam (quite firm and dense open cell foam). The outer diameter of the cylinder barely fit in the back of the driver.
Here is my theory, the backcup and the small vent are a resonating system. The resonance is around 50-60HZ I guess.
If I recall correctly, some member in this thread mentioned he had channel volume difference of his T40. I admit I realized that problem too. But for me, the two drivers are identical once the frequency goes over 500HZ. It is really the low-end that makes me feel the channel are not balanced(one being louder than another.). But after this mod, I also notice in the place where the left plug attaches the earcup, there is a very small hole that allows the air to leak out. That small hole contributed to the low-end difference of the two drivers. after I blocked the leakage with some putty, I ensure that my two drivers have the same back volume and vent size. Right now everything sounds correctly positioned.
I am really happy today because I love the highs of T40 very much and I successfully bring up the lows tonight.
EDIT: I may add some cotton in the cup to make the mids less lush and the bass less boomy. I'd never though I need to make the T40 V1 less boomy.
EDIT2: I added a little more damping, but using a slightly longer cylinder foam. Now I feel very happy with the sound. Audioable at 16HZ....rolled off but vibration is there. effortless all over the spectrum and well balanced. Best closed can ever.period.
