yups , go get the cw31 and some long eartips . you will not regret , nice build , low in microphonics , i love it , hope it wont disappoint you too .nice signature too .
Multi-IEM Review - 352 IEMs compared (Pump Audio Earphones added 04/03/16 p. 1106)
- Thread starter ljokerl
- Tags
- skullcandy-inkd-earbuds-2009 meelectronics xears-td-iii-v2 tekfusion jh-audio-jh13-pro-custom-in-ear-monitors soundmagic-e30 fischer-audio-dba-02 xears-xe200pro narmoo meelectronics-cx21p-in-ear-headphones in-ear custom-in-ear-monitors jvc-ha-fx34s-marshmallow-in-ear-headphones-silver spider-realvoice-vertical-in-the-ear-headphone dunu-dn-22m-detonator-headphones-earphones head-direct-re0-in-ear-headphones soundmagic-e10 visang-vs-k1 denon-ah-c360-advanced-in-ear-headphones soundmagic vsonic-vc02
zerocrack
- Apr 14, 2012
http://www.amazon.com/MEElectronics-Clarity-Headphone-Microphone-Smartphones/dp/B004OBZ2U4/ref=sr_1_1?ie=UTF8&qid=1334467799&sr=8-1
http://www.amazon.com/MEElectronics-Clarity-CC51-WT-Ceramic-Headphone/dp/B004OBZ2W2/ref=sr_1_2?ie=UTF8&qid=1334467799&sr=8-2
the only different between these 2 is one has microphone and one doesnt. Is this correct? Somehow the one with microphone is cheaper but has worst review. Just wanna double check before i order.
tinyman392
Be nice to noobs, we were all noobs at one point in our life.
- Apr 27, 2011
Same model, as stated. Only difference is the mic.
kanuka
- Dec 12, 2010
if that's the case , maybe the cw31 is better suited. but you could consider the gr06 for £32
Cant seem to find any UK stockist - same issue with Xears, would have loved the TD-III or similar but cant find any UK or EU stockists D:
frogbeats.com should have the gr06 by this week. drop them a email
for the Xears you can get them directly from xears.com. but that might be 8 euro for shipping
Cu Chulainn
- Aug 12, 2011
Thanks for all the time you put into this Joker!
Cu Chulainn
- Aug 12, 2011
Thanks, shipping just pushes it out of my budget.
Would it be worth waiting to get the GR06s over the R02s?
kanuka
- Dec 12, 2010
i think it's worth
Xinn3r
- Sep 1, 2011
Joker, I'm thinking of buying a CK10... will my iPod Touch / Clip+ be able to drive them properly?
justaguy
- Oct 10, 2011
Sorry, not yet. I have yet to compare them to anything in their price bracket. Hope to have the review done this coming week, though.
great news!
ljokerl
Portables Reviewerus Prolificus
- Mar 2, 2009
If you don't need the mic I would suggest not getting it - adding another part into the mix can't improve reliability.
Yes, they are more sensitive to seal/fit than source.
Xinn3r
- Sep 1, 2011
Ah.. perfect... I never had a problem with IEM fit before... hope I'll not have a problem with the CK10 either
justaguy
- Oct 10, 2011
My turn to appreciate all your efforts joker!!
What is the biggest soundstage among IEMs you've tried regardless the price?
leoily
- Mar 19, 2012
Mark,tanks
Xinn3r
- Sep 1, 2011
Joker, do you know if Green House's DBA-02 is the same as Fischer's DBA-02?
insalacosm
- Apr 17, 2012
[size=medium]Hello – for a newbie like me, I really appreciate all the good info in this threat, thanks! I purchased my first set of IEMs a couple weeks ago to use with my new iPhone, and ended up purchasing the Klipsch S4i based on CNET and other reviews. I was very disappointed when I first tried them out – they fell out of my ears even with the largest tips, the wires tangled like crazy, I wasn’t prepared for the microphonics and bone noise, and the mic was very sensitive to wind. Through some research I found that some of these issues are inherent with IEMs, and after using them for a week or so I got used to much of these issues but having to push the buds back into my ear every minute was a pain. [/size]
[size=medium]I wanted to try a different set so I picked up a pair of the new Sony XBA-1iP’s late last week. The first thing I noticed was the flat wires don’t tangle as much and I was able to find a pair of tips that fit really well. I spent some time doing a side by side comparison with the S4i’s (with the Sony tips on) and realized how much bass the S4i’s have, almost to the point where it muddles the mids and highs. I don’t have a great ear for this stuff but the XBA-1iP’s sound pretty good to me, better than the S4i’s at least. I listen to a variety of music (no modern rap though) and while doing a sound comparison between the two with a classical piece, I noticed some white noise/hum with the S4i’s. Regarding the mic, I’ve been told my voice still sounds distant when I use the mic on the XBA-1iP’s but the wind doesn’t affect it as much so I would say it is also better than the S4i’s. [/size]
[size=medium]I have a couple more weeks to return either set but at this point I like the XBA-1iP’s better than the S4i’s. Does anyone have any opinions to share on the XBA-1iP’s? Any suggestions on an iPhone compatible set of earphones that are under $100?[/size]
[size=medium]Thanks,[/size]
[size=medium]Steve[/size]
Total: 9 (members: 0, guests: 9)
