50an6xy06r6n
- Dec 16, 2010
I suppose I should be fine then, the GR07 seem like a safe bet for all types of genres and the price point is attractive, How have you found the sound stage and fit?
Compared to my other IEMs, the GR07s have a noticeably larger soundstage, but it's not huge compared to full-sized headphones, obviously. The fit is nice because of the rotating nozzles, but at least my set from the original batch had a limited choice of tips, and some have reported issues not getting a good seal with the provided tips. However, the newer batch, which is what you should get if you order them, comes with a huge selection of fake Sony hybrid tips, so you should be fine on that count. Also, if you have an unusually small outer-ear, you might have fit issues with the shell, but unless you have very small ears, this shouldn't be an issue. If it fits your ear, it's very comfortable though. (I've exaggerated fit issues so you're aware of them; it's really not that hard to get a good fit).
