ljokerl
Portables Reviewerus Prolificus
- Mar 2, 2009
im trying to find a "fun" ba without breaking the bank, in my range are the sf4 mee a151 soundmagic pl50 i think the superfi5 at around $90-100 would be a stretch for me, and thats all i know of. you just said the pl50 have the least low end, so i guess that means its only between the sf4 and a151? which sounds closest to a air dispersing moving coil?
Pretty sure they use the same driver so it would be a toss up. They are tuned similarly - the MEElecs just have better bass depth and generally sound a bit leaner and more controlled.
Indeed they do. The only minor difference I can tell in the housings is the TFTA's look like they have some sort of design on the outside. I wonder if it's the same drivers too? Now I'm really curious if the Aksent is the same as the TFTA-2100-3V2B at about a third of the price hahaha.
Well, someone's going to have to buy both and find out. I was impressed with the Aksent considering the amount of bass it had to deal with.
Hi joker, what do you think of the Fischer Audio SBA-03. I am thinking of getting either that or the Tandem, but I can't decide which. Bass is important to me, but one thing I do like is to have the mids stand out just as well and clear but recessed highs. This is coming from a set of low end Shures. What do you think?
You want the Tandem. I would not say the SBA-03 has recessed highs even though it is most aggressive in the midrange.
Are there any plans of doing a review of the Grado GR8 anytime soon?
All planned reviews are listed on the front page, below the table. No plans for the GR8.
