bmeat
- Sep 7, 2011
void
anyone heard the apple in ear and know if it sounds better than a superfi4 a151 or pl50? i would like it to have a good soundstage better depth and sound and as close to a moving coil as possible, just more low end basically the synthesizer drops just dont sound the same :'( but i love how they show the instruments so much more like under a razor very easy to hear instrument sepeartion and where they are coming from thats what i want a ba
(3B30) Brainwavz Beta
Reviewed Nov 2011
Details: half in-ear earphone with a good price/performance ratio
Current Price: $29 from amazon.com (MSRP: $28.50)
Specs: Driver: Dynamic | Imp: 16Ω | Sens: 110 dB | Freq: 20-20k Hz | Cable: 3.9’ I-plug
Nozzle Size: 5mm | Preferred tips: stock Comply foams, generic bi-flanges
Wear Style: Straight down
Accessories (1.5/5) – Single-flange silicone tips (3 sizes) and comply foam tips
Build Quality (3/5) – The construction of the Beta is similar to Sony IEMs of yesteryear, with plastic housings and long strain reliefs. The cable is thin and somewhat tangle-prone, similar to what is found on Fischer’s FA-788
Isolation (3/5) – Decent for a shallow-insertion design, especially with the included Comply eartips
Microphonics (3.5/5) – Surprisingly mild despite the earphones having to be worn cable-down
Comfort (4/5) – The half in-ear housings of the Beta are lightweight and sit well in the ear. The design mandates shallow insertion and the included Comply tips help comfort further, though replacing them can be a costly affair
Sound (6.7/10) – The Beta is an accurate earphone with fairly neutral tone and surprising range. For a half in-ear design, its bass has impressive depth and impact, both vastly superior to Fischer Audio’s similarly-priced FA-788. It is also punchier than the higher-end M1 model and the pricier Hippo 10EB. The bass is very clean and articulate and maintains impressive resolution for an earphone in the Beta’s price range – those not expecting a bass monster are sure to be pleased.
The mids of the Beta are recessed slightly compared to the bass and come across sounding a touch distant next to the M1 model. Clarity is excellent, however, and exaggerated further by the prominent treble. Detail resolution, too, is impressive for the price and the sound produced is clean, crisp, and edgy. The Beta is not something I would recommend for vocal-centric genres over the M1 but its reproduction of guitars has just the right amount of bite and texture. Whereas the M1 is refined and extremely smooth, the Beta is raw and full of energy.
There is a downside to the wild sound, however – at times the upper midrange and lower treble can come across wildly uncontrolled. The top end can be a touch splashy and sibilance ranges from mild to moderate depending on track, fit, and tips used. The included Complys do a good job of taming most of the treble but the Beta can still be fatiguing at higher volumes. Those who listen with the volume turned down, though, will find sparkly, clear, and moderately extended treble well worth the asking price.
In terms of presentation, the Beta is airy and open-sounding. Soundstage width is excellent and depth isn’t bad, either. Fischer’s FA-788 sounds much smaller and more congested in comparison and even the similarly open-sounding Hippo 10EB can’t match the soundstage size of the Beta. That said, the beta isn’t the most resolving earphone and doesn’t separate quite as well as the Brainwavz M1 does once things get busy. In addition, the space is not quite as cohesive and the imaging lags a little behind the M1. For its price, however, the Beta performs more than adequately and the sheer size of its soundstage is certain to impress.
Value (9/10) – While the old Beta Brainwavz Pro was a great value as an overall package, the new Beta gets by on sound quality alone. Like most entry-level half in-ear designs, it is not the best-built or most isolating set of earphones but for the asking price – and with sound quality this good – it is easy enough to forgive. Simply put, aside from a bit of sibilance the Beta may just be the best-sounding earphone in its price bracket. If that matters more than the functional nuances – as it should to many here at Head-Fi – there is no reason not to buy one.
Pros: comfortable half in-ear design; best-in-class sound quality
Cons: tangle-prone cabling; can be sibilant
(3C20) Section 8 Earbuds
Reviewed Nov 2011
Details: bargain-bin earphones with endorsements ranging from Elvis to Tupac
Current Price: $10 from amazon.com (MSRP: $19.99)
Specs: Driver: Dynamic | Imp: 16Ω | Sens: N/A | Freq: 20-20k Hz | Cable: 3.9’ I-plug
Nozzle Size: 5mm | Preferred tips: generic single-flange
Wear Style: Straight down or over-the-ear
Accessories (1/5) – Single-flange silicone tips (3 sizes)
Build Quality (3/5) – The metal housings and nylon-sheathed cables are impressive at the price point but the lack of strain reliefs says little for long-term durability
Isolation (3.5/5) – Typical for a straight-barrel dynamic-driver earphone
Microphonics (3/5) – Mild when worn cable-down; very low when worn over-the-ear
Comfort (3.5/5) – Typical for a straight-barrel IEM. Housings are very lightweight and the housing lacks sharp edges, which helps.
Sound (3.7/10) – The Section 8 Earbuds are by no means Hi-Fi but they do sound surprisingly decent for the asking price. Clarity is vastly superior to that of the similarly-priced Skullcandy Smokin’ buds and the bass is deeper and less washed-out. The muddiness and warmth of the Smokin’ are gone as well, leaving a low end that, while not particularly detailed, doesn’t crowd out the midrange.
The mids are clean and clear, on the cold side in tone and a bit distant. There is a tinge to the upper midrange that makes the Section 8 buds sound a touch metallic and the earphones tend to distort more quickly than higher-end sets as the volume is turned up. The treble is prominent enough down low and rolls off towards the top. The soundstage is below average in size but the relatively decent bass control keeps it congestion-free compared to that of entry-level Skullcandy products. Layering, as expected for the price, is nearly nonexistent, making the earphones sound quite flat.
Value (7/10) – The Section 8 Earbuds are a competent bargain-bin product with a generic form factor and surprisingly clear sound. Available in a number of celebrity flavors, they put similarly-priced Skullcandy earphones to shame and can be a genuinely inoffensive listen, though those looking for fidelity will want to keep on saving up.
Pros: decent clarity, comfort, and isolation
Cons: distant sound with a metallic edge
I have a random newb question - what's the best way to burn-in earphones without causing damage to the drivers? I usually play some music from my computer for about 3-4 hours (medium volume), then I leave it overnight plugged into my computer with this burn-in audio file (medium vol), plus any additional listening I may do that day with my mp3 player.
Joker, have I ever told you how awesome you are?
Edit: Same with you Inks, your pretty awesome as well.
the apple in ear really only deserve a 6.2 while the a151 and likes get a 7+? did they really do that bad with designing
let me rephase it my question. i dont need it to have lots of bass, i actually like a balanced (or a little more bass than flat) responce, but i want to be able to feel the bass there is, which i havent been able to do with the superfi4. will the apple in ear allow me to since it has a dedicated woofer?
