- Mar 20, 2010
Just got my DT990/32. Great condition. Sounds stellar.
The rubberband mod made the AD700 even less comfortable... @_@
Wow, I'm sitting here listening to my DT990/32. I subconsciously reached for the volume knob to lower the volume...problem is, I was reaching for the NFB5's volume knob... and I no longer own the NFB5. I have to pick up the E17 and lower it with face buttons. Sigh, I miss my NFB5. That volume knob was just so lovely.
For whatever platform, a fun flight sim game or, even better, space flight sim, would be a fantastic platform for 3D surround sound. I personally think it could see the kind of console renaissance as we saw with FPS games that dominate the scene now, with a great game executed well.
I would think Sony would make the PS3 able to play any DVD or Blu-ray disk, no matter what audio standard is used.
And whoever makes the Blu-ray movie disks would provide enough different audio track "standards" to allow their disk to be played with different audio setups.
As S/PDIF (optical & coaxial) can not pass Dolby True-HD or DTS-HD Master Audio, you not going to get the "full audio experience" no matter what optical input device you use.
I would guess you would need to use HDMI for the "full audio experience".
I would guess something like Dolby Digital 5.1 or DTS-EX audio might be hiding somewhere on the Blu-ray movie disk.
I would think once the PS3 turns DTS-EX audio signals into PCM, the PS3's DDL (Dolby Digital Live) should be able to compress it and send it thru the optical.
]I have found certain tricks on using the Bitstream (Mix) setting for the BD Audio Output (Optical) setting on the PS3; actually a few.
This tutorial will show you how to use the Bitstream (Mix) setting to your advantage.
I've tested this setting and can prove to be useful for folks who have OLD Digital Surround setups (Receivers that don't support DTS, but does support Dolby Digital), and they tried to play back their DTS-HD enabled Blu-rays but only got no sound or Stereo sound.
Also, another trick became very useful to potentially get better quality sound for Blu-ray movies that have Dolby TrueHD and make it play back in DTS for folks who have a DTS/Dolby Digital supported receiver, but doesn't support the HD variants.
Anyways...
Make sure your PS3 has FW 3.30 or higher for this to work, I'm pretty sure all of you do have the latest FW.
Blu-ray movies with only DTS-HD Support for the main track and how to play back in Dolby Digital:
This is for the small number of people who have a much older receiver that lacks DTS support, but has Dolby Digital. These people are likely to be buying the latest Blu-ray movies that have only DTS-HD support for the English audio. If the setting for the BD Audio Out on Optical is set for Bitstream (Direct), and the Audio Output Settings has only Dolby Digital enabled (not DTS), they'll only get stereo sound. If Bitstream (Mix) is enabled, those Blu-ray movies with DTS-HD as the main audiotrack will be transcoded to Dolby Digital, and then you would have 5.1 audio.
This is not true, at least in the case of the main language (secondary languages like French and Spanish do tend to be encoded with Dolby Digital). Almost all Blu-Rays are encoded with DTS tracks. If you don't have DTS checked, the PS3 will automatically revert to 2 channel PCM (which is why you can't EVER uncheck it in audio settings). If you uncheck DTS, and keep Dolby Digital, the Blu-Rays will still default to 2 channel PCM. This is exactly why the Mixamp and other virtual surround device users are out of luck when watching Blu-Rays. We can't get Dolby Digital so it can be changed to Dolby Headphone. We simply have to deal with these devices adding reverb to a basic stereo signal.
If you have both DTS and Dolby Digital checked on the PS3, the Mixamp, etc won't play any audio, because the Blu-Rays are only playing DTS.
However, certain receivers (like certain Harman Kardan receivers), WILL convert DTS to Dolby Digital and then to Dolby Headphone.
Now, if you can somehow find me this 'hidden' Dolby track that I can feed to the PS3's optical out while watching Blu-Rays, you will officially be my audio savior.
As far as Dolby Digital True HD, and DTS-HDMA and what have you, yes they do have the basic non-HD tracks hidden within them. Like if you're playing a DTS-HDMA movie, the optical will use the basic DTS signal. The rare few movies that use Dolby Audio, will have the hidden Dolby Digital track (I believe Dreamworks movies seem to go Dolby instead of DTS).
