Well...just got in the Epos H6Pro and GSX 300 AMP/DAC.
H6Pro:
GSX 300:
Really impressed with the build quality here on both units, one interesting note is that the Headphone out/Microphone out is located on the back of the GSX300. Which are first, I thought was odd as I'm use to plugging things in at the front of the device but this allows me to hid the cables and route them underneath my desk. This setup looks extremely clean and the cables provided are long enough!
The H6Pro I received is the 'closed' version and they isolate extremely well! Comfort, fit and weight is extremely satisfying with this headset and feels well built! The cables although perfect in length are of the braided type and seems to have some memory to it, comes bundled up and as you untie them they literally turn in to a slinky! Good luck trying to get these types of cable dead flat and straight as they seem to stay stringy and curl about the place like a fish out of water! Not a deal breaker as the micro-phonics is not noticeable but something Epos could improve on in the future! Earpads are large and comfortable, these are like the hybrid pads with the pleater on the outer and fabric inside, my ears are comfortable inside and have no issues at all! Headband and adjustability is something Epos nailed here, once my head, I never wanted to take them off!
The sound of H6Pro Closed is very pleasant, Epos and Sennheiser collaboration here is evident and they just sound right to an Audiophile/Gamer ears here. It's got punch down low which is detailed and tight but is not pushed forward or overcomes the rest of the frequency range but present enough to give you that warm Sennheiser taste. Midrange is also typical here, clear and present and ever-so-slightly recessed. It doesn't come across too shout nor too distant but just right, sorta like the HD650! I love how the treble is done here on the H6Pro, not sibilant but detailed, airy and forward enough to give you that little extra sparkle on top! All this combined probably makes the H6Pro sound like a fun headphone, which it is....but in games like Apex Legends, CSGO, Battletech, DOTA Underlords....it was all a great experience and with the added bonus of being totally isolated to the rest of the world! Imaging and sound stage is excellent here and for a closed-back it never sounded like one, the H6Pro reminded me very much of a Closed-HD560s but with a warmer and less analytical sound signature. Something I've actually been looking for since I've acquired the HD560s because I'm just so impressed with that headphone! Fairly dark background, not the darkest I've heard but no distortion or cup resonance and the image is of a larger sound scape compared to other closed-back I've heard. The depth is quite good here, things are happening all around your ears and head with Left, Center, Right being very accurate. Tracking sounds and hearing footsteps is no issue here, the detail and balance of the sound signature just provides you with an excellent production of what is going on the game or whatever media you use with this headphone!
The microphone on the H6Pro is up there with a Modmic and in-between a Razer Siren Mini and other various microphones I have. It is highly useable and for most gamers who aren't looking for Podcast style solutions then the microphone on the H6Pro is a one and done solution! You can raise and lower the microphone arm, which mutes and unmutes as you fold it away or bring down to use. You can even take off the microphone all together as Epos used a magnet solution to hold in-place the microphone arm! They even include little disc covers to replace the microphone if you decided that you don't want to use it! Very handy!
Epos GSX 300 AMP/DAC/Software:
The Epos Gaming Suite, is tiny in comparisons to other Bloatware programs out there in the wild, this is a thumbs up! Simple to use and not overly complicated to use, it does what it needs to do fairly efficiently and just gets out of the way!
Below, you have control of your microphone capabilities where you can adjust and fine-tune a quite a lot! You can EQ your mic-out to
make your voice sound warmer, clearer, or EQ to whatever you like. You can control the Gain, Side tone (for all those who need to monitor
their mic levels!), Noise Gate and Noise Cancellation. All very easy to adjust and test while you're in the software!
Below: You can EQ yourself or use custom presets, I just left mine on Flat as I don't really use EQ! You can change between Stereo or 7.1
Simulated Surround setting and adjust the Reverb! I just prefer Stereo here but YMMV.
All in all the software is usable gives you a little tweaking if and when you need it and it doesn't take up silly amounts of virtual HD space
being only 18 megabytes!
Next is the GSX 300: Small petite but firm and well built, slightly heavier than you might think. Reminds me of the Old
Audioengine D1 from back in the day! Volume is soft and clicks as your turn, has a nice feel when you seldom turn it
up or down as I have the volume for the H6Pro set to 50% and is ample for everything I need it to do! The other button
is a select button and you can customize this to do a few things through the software. I just have mine to toggle between
Stereo or 7.1!
The rear of the unit is tapers down and just has your bare essentials for a gaming DAC/AMP. Headphone-out, Microphone-in and USB micro for power and data.
As I said before, this was odd at first but later worked out extremely well for my setup and just looks really nice once I set it all up! If you like clean setups then
having the cables route out the back of the DAC and around or under your desk looks clean aF.
Performance wise, the GSX 300 is competent and powerful enough with the H6Pro, I haven't tried any other headphones with it yet as I intend to keep this setup straight
forward with the H6Pro/GSX300 combo going forward!
I have no issues with the sound quality this little DAC pumps out and no issues installation or any driver issues, essentially plug and play! I've not heard any pops or clicks or distortion or anything which is a relief to me which further solidify my purchase. It probably sounds better than my Schiit Fulla 2 and on pair with my Creative X3, does it compare to my other standalone DAC's well....does it matter? Not really....it just needs to do the job I want it to do and it does it rather well!
As for value, I picked these units up on the 'used' markets but both units were 'brand new' and the H6Pro wasn't even opened, still with the seal! I'm not sure if I'd personally pay full retail price for a "gaming" headset and DAC but for what it does, it does really well and I'm keeping this combo!
@Mad Lust Envy - Sorry in advanced if it looks like I tried taking over the thread but I personally love and use your thread you've created and just wanted to add to it as it's been a really pleasure read through your thread throughout the years!
