WhiteHartMart
Using a G6 and K712 Pro combo here on PS4 and G6 has more than enough in reserve to drive the AKGs
Thx for the reply. Yes I'm gaming on PC and my graphic card just died and now I'm upgrading whole thing.
CPU: i5 4670K
Motherboard: MSI Z87-GD65 Gaming
This is my current build. Still waiting for my graphic card to come (day or two). In near future I'm also upgrading my board and than RAMs, CPU and so on. But for now only graphic card (bought also freesync monitor) and sound (headphones, amp).
Sennheiser 599 cost me 110€ and K701 are around 120-130. No difference here, just need to know which are more suitable.
I sold off my X6 and nowadays am just fine with the G6.
I use the G6 sending an optical signal to my Mixamp 5.8. Zero issues. Beforte anyone asks, it's because the Mixamp 5.8 can't do virtual surround for my PC, which is my main use, so I just have the G6 send SBX surround to y 5.8 (Dolby Headphone button off, obviously as SBX is already doing surround).
The X7 had driver fixes waaaaaay after release. Remember NOT having SBX being piped through the optical and analog out? I sure do. They added that way down the line. They certainly didn't have to. No one else does that. Creative did. That wasn't a feature that was there for likely the first 1-2 years.
So to say they don't listen to the community, I don't believe that, because it was the community that begged for things like that.
- Why did you sell your SoundBlaster X7?
- If you could have Sennheiser GSX1000/GSX1200 with digital output with the 3D virtualization OR incl. with a beefier headphone amp, would this be your choice over the SoundBlasterX G6 for gaming?
I'm still on X7 with my favourite closed headphones, Audeze Mobius still unopened in box and thinking which route to go. Once I settle, I don't like to tinker and change the system every day (not enough time for that).
Hello guys, im new here and just logged in to ask this question.
I read about MLE's reviews about gaming amps & headphones.
Im using the asus xonar u3 usb sound card with ad700x for a few months now.
I use dolby headphone feature and its statisfying generally for music and general gaming stuff for fps games though its another story.
I'm not quite pleased with its directional audio performance. So I read in MLE's review he compared u3 with amps like gsx 1000 and g6, now, im interested in positional accuracy the most because i like competitive playing.
Im wondering if the upgrade to gsx 1000 or g6 (i lean towards gsx because the general comments say its better for gaming with vss) will be worth it since im living in a 3rd world country and this stuff is quite expensive here I wanted to ask and know you guys opinions, should i continue on with my u3 or get one of these for gaming. Btw thank you for this informative guide. Cheers.
Hello guys
I need really serious advice
I have Denon D600 with Asus STX II soundcard (Dolby Headphone option enabled)
I’m really satisfied with this combo, very comfort headphones with big soundstage and rich bass, great soundcard, but I just want something more, like an upgraded D600, headphones which will be better than D600 in every aspect (not worse at least)
First step is new headphones, second is external DAC. This post is about first step
May be I should create new topic but I decided to post here
So here is my specific needs:
Headphones type: Closed over-ear
Usage and needs:
60% first person shooter gaming -> Big/wide soundstage and very accurate sound positioning
30% music (generally hip-hop mp3 320kb/s) -> Rich bass
10% movies, youtube, etc. -> Max comfort wearing like my D600 which I can wear for 6-8 hours without any discomfort
Price limit: 1000$
Stick with the shp9500. The only headphones I consider to be an upgrade are the focal elex but those are $700 on massdrop.Hello guys! I need some help of you guys.
So, for gaming, my corrent setup is gsx1000, shp9500s and v-moda boom pro.
I think is time to step up the headphones. What do you guys recomend?
I was looking to gsp 500/600 or AKG712 or hd5xx jubilee or hd6xx...
Do you guys recomend any of those or anything diferent?
Thanks
