Mad Lust Envy's Headphone Gaming Guide: (8/18/2022: iFi GO Blu Review Added)
Jul 2, 2018 at 12:57 PM Post #40,441 of 48,565
Hey man
I just ordered the DSS2 off Amazon UK. Got them for 25£ and based on the reviews, they should fit the bill until I find the Holy Grail of gaming dac/amps! The X7 was just too expensive
Expensive is relative, haha! I saved for more than half a year to get ready to buy the X7 on release, but I ended up getting a review sample (and wrote my review before Earphonia, but I didn’t know about Social Media much back then). That was... several years ago? Budget is bigger now! But so far, I used the X7 the most when it comes to console gaming with headphone surround.
Jul 2, 2018 at 1:25 PM Post #40,442 of 48,565
Hello!
I've been looking at headsets now for hours and im not getting anywhere, I have no idea what to get. there's just so many.. I'm close to ordering either a HyperX Cloud II or a HyperX Cloud Alpha.. just so I get something to replace my steelseries which actually fell apart yesterday (had it for way too long and it's not even good)
I want good positional audio, or good enough, and roomy for my ears, big headphones that doesn't hurt me for long long gaming sessions. with a budget of $100 roughly..
and I read you should get open back, would it be stupid to go for the HyperX? Like would that be a waste? If I could get something else not made for gaming that is better for competetive and then sort myself a mic in another way. Though you want some "fun" sound.
I play with voice activation always.
any thoughts about this dilemma?
Welcome to Head-Fi, sorry about your wallet!
This is a common question, and it essentially boils down to “there are many great options.” Did @AxelCloris finish his Kingston headset reviews?
Positional audio comes from a DSP (Digital Signal Processor) like a sound card or external processor, or sometimes from processing built-in to a handful of games (Battlefield, PUBG, Hellblade: Senua’s Sacrifice, Overwatch for PC, and Starcraft II come to mind). Obviously games with a headphone surround mode built-in are cheapest, but they’re not in every game and usually a dedicated processor has more sophisticated surround emulation than what’s built-in to some games. If you click the link in my signature, you’ll see my DSP reviews before I had to stop writing them. If positional audio is important to you, that should be included in your budget.
The best gaming headphones under $100 (minus DSP price) is hard to find, there are a few decent options but almost universally I find them to sound a bit “cutting” and fatiguing compared to somerging nicer. That said, some headphones formerly priced at $250 and above have come way down in price, and there are great values out there.
Jul 2, 2018 at 1:30 PM Post #40,443 of 48,565
can i ask you some questions for AKG K702 and AKG K712 Pro?
from these 2 which you think is better in gaming music and movies??
do you believe that AKG K702 and AKG K712 Pro are very old headphones with old technology??
have you tested AKG K702 and AKG K712 Pro?
also how AKG K712 Pro performs in music and games??
can you aswere me in all these questions please/?
and also if i buy soyndblaster ae-5 with AKG K712 Pro do you believe that will be a massive combo for gaming music and movies??
Jul 2, 2018 at 1:32 PM Post #40,444 of 48,565
WITH THE REVIEW OF Mad Lust Envy. FOR THE DO YOU Agree in everything he SAID WHEN HE DID THE REVIEW FOR K712 Pro????
OR YOY ARE NEGATIVE IN HIS REVIEWS WITH SOMETHING THAT YOU DONT AGREE WITH HIM?? ABOUT K712 Pro????
SO K712 Pro DO YOU BELIEVE THAT IS EXCELLENT IN EVERYTHING?
reading this review?? from Mad Lust Envy??
Build Quality:
Rating: Great
I'll basically paste what I've said about the K702 65th Anniversary, as the build is absolutely identical to the Annie. The only differences between the color differences (Annie is gunmetal with blue bars and accents, K712 Pro is black with orange bars and accents).
Made of a durable plastic, and well thought out design, I find the build quality to be great. I wouldn't toss them around haphazardly, but they'd definitely survive some abuse. The detachable cable is like the non-Anniversary models, which isn't the thickest I've seen, but certainly very malleable, flexible, and light. It certainly does it's job, though I would have expected a more rugged, or fancier cable for these higher priced variants.
Compared to the non-Anniversary models of the K701/K702/Q701, the headband is thinner in width when viewed from the top/bottom, with a widening of the area where the AKG branding is located. The biggest difference (and it's incredibly significant), is that the underside of the headband no longer has the notorious (7-8) bumps, and is instead completely smooth. This basically turns the K712 Pro from a torture device to a very comfortable headphone. There is no padding, but it is mostly unnecessary as the headband perfectly molds to your head, distributing pressure evenly across where it rests. The bumped headbands were notorious for digging into the scalp, especially on the center one or two bumps. Why it took AKG this long to rectify this issue the vast majority of people had is beyond me, but it's finally done.
The headband also has the added benefit of allowing bigger heads to fit due to less stiffness, and more space. Prior to the K712 Pro and K702 Anniversary, I basically needed the other models to be fully extended for them to fit my head. This caused a lot of tight, downwards pressure, which in addition to the hard bumps, didn't lead to the most comfortable headband design. It took me a few days to adjust to the older models, and I didn't find them as problematic as most people still do.
The pads are the second most significant change from the older models. They are made of memory foam inside velour. Very dense and molds to your head shape MUCH more than the older model pads. This causes a better seal, which is more than likely the main reason why the sound signature is warmer, and more bassy (from my experience with using a Q701 with the Annie pads, I found the Q701 to sound 99.9% the same as the Annie, with a slightly brighter tone which may have just been driver variation).
Accessories:
  • Velvet carrying pouch: One of the best carrying pouches I've seen bundled with headphones. It's thick and feels great, though it won't protect a headphone from much except dust and scuff/scratches.
  • Long coiled cable (black)
  • Straight cable (orange) w/6.3mm screw on adapter
Comfort:
Rating: Amazing
As previously mentioned, due to the new headband and new pads, the K712 Pro has made a noticeable boost in comfort over the older models. The headband change is significant for comfort. The removal of the dreaded bumps would basically satisfy ANYONE who had issues with them on the older models, and even those that don't have issues with the bumps.
The pads are arguable, as the standard 7xx pads, while more firm, breathed a little easier than the new memory foam velours. In either case, neither are sweat inducing or uncomfortable, personally. The new memory foam pads molds to the shape of one's head, leading to no uneven pressure. I find the older models to be not as uncomfortable as most people would lead to believe, but the K712 Pro would more than likely satisfy those who have problems with the older pads.
The K712 pro is easily one of the most comfortable full-sized headphones I've ever worn.
Design Issues:
There really isn't anything to complain about with the K712 Pro. If anything, some may not particularly like how big the cups are, but that's the nature of a full-sized over ear headphone. AKG has more or less perfected their 7xx design, fixing all of the previous issues people had with them (headband bumps being the main problem). The only thing I can see improving upon this design is to add some padding underneath the currently bare headband strap, which would further drive the comfort towards perfection.
Isolation/Leakage:
Rating: Poor
The K712 Pro is a fully open headphone, and as such, it is expected not to perform well for noise isolation/leakage. As I mention time and time again, reports of open headphone's leak tend to be severely exaggerated. Yes, you may bother someone in the same room, but never someone in another room, even with the door open. Unless you need absolute silence in the same room, open headphones don't leak so loud as to bother most people, possibly even if they were in the same room.
Sound:
Rating: Amazing
People will undoubtedly complain about the incremental improvements constantly being made to their 7xx drivers, but to those who haven't experienced every little upgrade (or even those who have) will find the K712 Pro to be the their strongest headphones yet based on their 7xx drivers. What you get in the K712 Pro is the most musical, and fleshed out variant, with a noticeable addition of bass, warmth, and pleasing tonality. AKG had previously made most of these improvements with the K702 65th Anniversary (aka Annie), but the Annie had some trade offs, particularly in the sense of spaciousness (not necessarily soundstage itself), and upper range clarity and detail (which were slightly lessened due to a smoother, less fatiguing upper range). The Annie was a slightly different flavor of the K712 Pro sound, with a thicker body of sound, more intimacy, and smoother, slightly more organic sound. I'm exaggerating the differences, as they are subtle, but a good ear can tell them apart.
The K712 is the perfect middle ground between the standard 7xx airy sound, and the Annie's warmer, more fluid presentation.
NOTE: I'm basing my assessment of the Annie with it's ORIGINAL memory foam pads, which AKG has since replaced with a taller memory foam. The new pads on the Annie may have closed the gap even more between the two headphones to the point where it may be harder to discern the differences in sound quality. I haven't heard the Annie with new pads, so I can't personally confirm. Just something to keep in mind, in case those with a newer Annie don't agree with what I say here.
Bass:
Rating: Excellent
The K712 pro's bass is quite well balanced and always present, favoring midbass over sub bass (which rolls off a little compared to the K612 Pro which maintains it's bass to very low levels, though isn't energetic and forward as the K712 Pro). The bass is full, fluid, and rich, creating some warmth and body to the meat of the K712's sound. Because the bass is very, very similar to the K702 Annie's bass, I will quote most of what I said about those, with a few edits:
Sound-wise, this is the most significant change coming off the older models. The K712 Pro presents bass quite well. You can consider it mildly above neutral. Natural if the source doesn't have a need for bass, and quite full and involving when the need for bass is there. Overall, the bass can be quite full, layered, textured, and infectious.
What it improves over the standard models is that the bass is no longer situational. It doesn't just hit with really bass heavy songs. It hits at all times, in a very natural way. Put on a bassy track, movie, game, etc, and the K712 Pro will impress. Make no mistake. I've always found the Q701, and particularly, the old K701 to be slightly below neutral. The bass would decay too quickly, and wouldn't hit with enough energy to give a sense of naturality. No longer an issue with the K712 Pro. Unless you're a basshead, I don't think there will be much to complain about here. If you like accurate, yet full bass, the K712 pro will impress.
Mids:
Rating: Great
The K712 Pro's mids sit between the 7xx's mids and the Annie's more upfront and intimate presentation. The K712's mids sound pushed back in comparison to the Annie, though not pushed back in the way of recession, but more because the soundstage is large and nothing is exactly upfront and in your face. The lower mids are aided by the lean towards bass that the K712 has, which results in a warm, and tonally realistic voicing compared to the standard 7xx and even the incredibly balanced K612 Pro, which comes of a little dry in direct comparison.
The one downside I see in the mids is that the patented AKG upper mids peak is still somewhat present, causing certain sounds to have an artificial etch to them, and seem out of place next to the K712 Pro's general warmth and smoothness. It isn't as pronounced as the standard 7xx models however, and the warm tonality and fleshed out signature of the K712 mitigate the fatigue a bit compared to the standard 7xx.
All in all, the K712's mids are more or less balanced with the rest of the sound, and are never lost or masked.
Treble:
Rating: Great
The K712's treble maintains a level of sparkle some found lacking on the Annie. The treble is generally smooth with some upper end peak as usual of the 7xx line, cutting off some extension as well as the fatigue that can be associated with too much treble in those ranges. The K712's treble adds some much beneficial air to the soundstage, as well as clarity and detail which isn't typical of warm/smooth headphones (which tend to roll off in the treble range).
I personally have to say that I really love the K712's treble as it isn't an everyday occurrence to find warm headphones that sparkle in the same way as the K712. I also love the original Annie's smoother, less fatiguing presentation, but it did come across more subdued. I'd say the K712's treble is generally more favorable, and more likely to please most people.
Soundstage:
Rating: Excellent
While the original Annie had a large soundstage, the thicker body of sound and smoother treble made the soundstage sound more restricted and congested compared to the standard 7xx and K712. The K712's soundstage is spacious, and excels particularly in width. The soundstage is dimensional, holographic, and layered. The K612 Pro didn't have the same dimensionality and layering in direct comparison, despite it's large size.
Positioning:
Rating: Excellent
A large soundstage, generally linear balance, and great detail is a recipe for success. The K712 excels in positional cues, much like the standard 7xx line, but with more body, and fullness. One can argue that it won't be as masterful for competitive gaming focus due to the standard 7xx model's tilt towards analyzing and detail-retrieval, but the K712 doesn't give up much in the way of those things, and adds in extra immersion.
Clarity:
Rating: Excellent
Objectively speaking, the standard 7xx models as well as the K612 Pro have a clearer tonality over the warmer, more musical K712 Pro. That being said, the refinement, musicality, and tonality of the K712 Pro is more natural sounding and realistic in comparison. The standard 7xx sounds artificially boosted for clarity, which may be good for raw detail, but bad for enjoyment. The K712 has excellent clarity, and I don't feel like I'm losing much of anything when choosing the K712 over the standard 7xx models.
Amping:
Necessary
The K712 Pro doesn't require much to sound fantastic, but as with all 7xx models, they scale up with better gear and amping. I would recommend a decent desktop amp for these. That being said, I enjoyed the K712 Pro with the Fiio E12, and didn't feel I needed much more. I can easily live quite happily with the K712 Pro and FiiO E12.
Personal Recommendation?
  • Movies, Music, In General? Yes
  • Gaming? Yes
The K712 Pro, is among my very favorite headphones I have ever heard, and currently my favorite open dynamic for all around use, even over the Philips Fidelio X1. If you're looking for the best all-rounder under $400, the K712 is one my absolute top recommendations. While I prefer the original Annie (flatter pads) for certain things (the mids and intimacy for music), the K712 has a better sound signature due to a clearer upper range and better sense of space which will benefit a larger amount of media, including gaming.
As a cheaper alternative, you can get a standard 7xx, and if you order some K712 pads for it, it essentially becomes a cheaper Annie/K712 Pro alternative for around $100 less than the Annie and K712 normally go for. It may not be completely identical, but it will be close. You also get the benefit of having both the standard pads as well as the K712 pads for easy swapping and tonality change. Your mileage may vary as driver variation needs to be taken into account. I recommend the K702 most for this, since it has a bumpless headband, while the K701 and Q701 still have the uncomfortable bumps, though will also benefit from this pad swap in the same exact way.
Final Impressions:
The K712 Pro has proven to be the best mid level AKG headphone in terms of musicality, refinement, and organic tonality. Yes, it doesn't stray far from that well known 7xx sound, but it eliminates most of what people disliked about them, while adding nearly all the things that were lacking (bass, warmth, organic sound). If you happen to like the standard 7xx and wished for more warmth, bass, and musicality, with less upper mid/lower treble fatigue, the K712 Pro demands your attention. I admit I was skeptical at first, seeing how much I love the original Annie and heard that the K712 reduced the intimacy. My fears were quelled, as the K712 gained it's own benefits over the smoother, original Annie, mainly in the addition of air/less congestion and upper range clarity.
I'm actually quite in love with the K712 Pro overall, and I find it to be a great endgame headphone for those without deep pockets. It's a safe bet to say that the K712 Pro is a headphone that I can recommend to practically anyone.
Spoiler: Fun: 8.25/10 (Great)
Jul 2, 2018 at 1:42 PM Post #40,445 of 48,565
@mikerrr
I can’t state my opinions on the AKG products anymore. I can’t say them in PM either.
Oh, by the way, when Mad wrote that review, he wrote “K7xx” to refer to “AKG’s line of K7_ _ series headphones, including the K701, K702, Q701, K702 Anniversary, K712 Pro.” Now, there actually is a product literally called the K7XX, and it’s a Massdrop.com exclusive deal on the K712 Pro.
Jul 4, 2018 at 2:15 PM Post #40,446 of 48,565
Thanks for input, I actually have the HyperX Cloud 2 now already but I might return them I'm not sure im satisfied (possible due to EU online purchase laws)... they feel very closed off and when I speak myself I sound like im in a tunnel.. def not as much bass everywhere in-game.. maybe a bit muffled sound im not sure...
if I feel this is just shutting too much noise out from the outside world, would I feel better with an open air? I had the steel series before this.. ..
so if I return these im actually prepared to spend more, say 150-200$ preferably .. 150ish and then get an alright mic for the rest, or a modmic and end up at $250ish..
The DSP thing might be something for future, if I'm first satisified with the feel of my headphones.
Have any recommendations for the higher budget?
I've also just come across this Superlux HD668
which is dirt cheap but still might suit my needs and be an entry level for me to move away from these gaming marketed headsets, you know about this one?
or maybe Superlux HD681 EVO
but.. I dont quite understand does open back mean sounds leak out of the headphone? wont the mic pic that up then? O.o
Jul 7, 2018 at 11:34 AM Post #40,447 of 48,565
Anyone that games on a PS4 use an x7? Did they finally add chat over usb or do you need a separate dongle to get chat audio to your PS4?
Ive been trying convince myself to get an x7 but the more i research, the more it seems it isn’t for me.
Jul 7, 2018 at 11:46 AM Post #40,448 of 48,565
Still need BT-W2 for chat
Jul 7, 2018 at 12:07 PM Post #40,449 of 48,565
Need the dongle for chat on the PS4
It's not a single use option - is overkill for that - and not cheap
It's the best thing by far to have if you have multiple uses though.
Further than that - it extends into higher end stuff invisibley.
If just for a solution for PS4 couch gaming with chat? Nah - grab a set of green neon wireless somethings that advertise for that
If after a total solution for PS4 and everything else? - and can deal with cords? - BEST THING EVER
Jul 7, 2018 at 5:53 PM Post #40,450 of 48,565
as i told you i did reasearch and i wan to buy the akg 712 pro because i read in alot of reviews from Mad Lust Envy's Headphone Gaming Guide: that these headseats are very good
but my question is akg712 pro very good for games and music and movies?
in games will i hear every detail in one game? example K712 in music because i am hearing music all the kind of music from rock and jazz opera greek music ,, electronic music techno trance progresive psy trance and watching movies.. how performs?? you can hear all the details which have all the kind of music??
also in games like fps rpg games,, fighthing games,, horror games in all the kind of games how performs??
i mean with k712 you can hear everything in one game??i mean all the details??
like sounds ,, water.. guns.. effects?? and all the detail which one game has?>?
so how is the
Build Quality
Isolation/Leakage:?
bass is it good?
the Mids and Treble are very good?
Soundstage: and Positioning? are very good?
Clarity? is it good?
do you believe that are very good for games and movies and music?
also from https://antlionaudio.com/collections/modmic-for-gaming which to buy??
there are 4 kinds
which you suggested me to buy??
do you believe that AKG K712 Pro will be a massive combo for gaming music and movies??
how is Build Quality
Isolation/Leakage:?
bass is good?
το Mids και το Treble is good??
το Soundstage: και το Positioning?in what level are??>
το Clarity? is it good?
because i want to buy the AKG K712 Pro
[merged]
Jul 8, 2018 at 6:23 AM Post #40,452 of 48,565
Got my DSS2 and so far so good, very satisfied with the surround sound that I am getting on my PS4 Pro (haven't tried them on my Xbox yet). No hissing, no drop in quality as far as I can tell when compared to my DAC/AMP setup, but then again I am no pro...
I am just glad I chose to go for the 80ohms version of the DT770 as the DSS2 is more than capable of outputting quality sound to the headphones without a need to add an amp to the equation!
