avens
- Mar 12, 2013
As long as the headphones have removable cable You're set. Just tie them up together. This is how it looks like with my HD598.
Alternatively, with the HD598 you can use a BoomPro cable/mic, by doing this.
http://www.head-fi.org/t/541039/sennheiser-hd-598-impressions-thread/2700#post_9752345
Then getting a 2.5mm to 3.5mm adapter, slim enough so that it fits.
That way the setup consists of only one cable, with the rather useful addition of an in-line volume control. Also this mod allows any 3.5mm to 3.5mm cable to be used with the HD598's.
The only possible issue is that you were to accidentally detach the inner-cabling, which is a distinct possibility. Years ago I performed the "foam mod" to my good old 555's and did precisely that, so I had to solder them back in.
edit: BTW I was going to do this mod last weekend to specifically use the BoomPro cable, but forgot. In any case it's confirmed this idea works. https://www.reddit.com/r/headphones/comments/2ro9bf/help_sennheiser_hd_598_vmoda_boompro_mic/crbgdoa
