Mad Lust Envy's Headphone Gaming Guide: (8/18/2022: iFi GO Blu Review Added)
- Thread starter Mad Lust Envy
- Tags
- akg-k612-pro-reference-studio-headphones akg-k712-pro akg-q701-premium-class-reference-headphones-quincy-jones-signature-line astro-a40-audio-system-white audeze audio-technica-ath-ad700 audio-technica-ath-m50-studio-monitor-headphones beyerdynamic-dt-770-pro-80-closed-studio-headphones hd800 hd800s headphones over-ear philips-shp2500-37-full-size-headphone-with-volume-control sennheiser-hd-598 shure-srh1540-headphones sony-mdr-ma900-over-the-head-style-headphones sony-mdr-xb700-50mm-xb-diaphragm-driver-extra-bass-headphones soundmagic-hp200
High Fidelity
- Jan 29, 2010
If I went with the AKG K7XX, and bought the Q701 ear pads for when I wanted more detail for competitive gaming, would the K7XX with Q701 pads be a better overall set of headphones - sound, comfort, build quality - than the Q701? How difficult is it to source and purchase the Q701 pads? Are the K7XX and Q701 the same to drive? I play a large assortment of games so it's possible that I would be swapping ear pads frequently. How difficult is it to remove the pads, and if doing so frequently, what's the chance that I would damage them or the headphones at some point?
They're the same difficulty to drive as they're the exact same hardware except for the pads. Pads are super easy to change, just twist and remove. I wouldn't expect a massive difference, tho. Might not be worth your while getting both. *shrug*
High Fidelity
- Jan 29, 2010
I noticed in your sig that you have the Xbox One > Wireless Mixamp 5.8 > AKG Q701 setup. How well does the Mixamp 5.8 drive the Q701? What position is your volume dial usually? I have the latest Mixamp Pro with the AD700, which is very easy to drive. I usually have my volume set to 1/6 of max, which is the first tick on the dial.
- Mar 20, 2010
SR-009 > HD 800
I dunno, even then, I still see a lot of people preferring the HD800. Probably because it's closer to neutral, while the 009 is more leaning towards brightness.
rudyae86
- Oct 10, 2013
From this point on, if anyone asks me what the best headphone is for $200, you guys can auto answer for me. The K7XX will be the easy answer, considering it's more than likely an Annie downmarked to a ridiculously affordable price level (by audiphile standards).
Seriously. Forget the MA900, K612, DT990 Pro. The K7XX for $200 is the one you'll want, IF you want a very balanced sound with some warmth in the bass and mids, and very good soundstage and comfort. You can then just buy some Q701 pads for it if you prefer a more detail focused and even more spacious sound. The only thing that keeps me from it is that it isn't exactly the easiest thing to drive when a mic is attached, which is why I'm still focused on the X2.
But only 6000 will be available......but that can change right? I dont think that would be the end of the line for a limited edition? If one thing runs this show, it has to be monaaaay lol
Heck, now that I joined the drop and practically bought one...if they ever release another limited edition ( not including the next 2 drops after this one, then again who knows lol) I would purchase another. I never owned an AKG but from what I read in other threads and stuf, it just seems that its a brand you just cant go wrong.
With that said, the X2 would still be my other top favorite headphone, for reasons you have already said. Easy to drive, flexibility with attaching a boom mic ( even the Phillips SHP9500 has a detachable cable, which MLE, you should check out)
And honestly the X1/X2 Should be sitting next to this AKG K7XX Just because they are very versatile in what they do.
When I'm not chatting, I have the volume at about 50-70% usually. When I'm chatting too, I have to use my E11 to double amp it; 100% doesn't get loud enough and it's super hissy.
rudyae86
- Oct 10, 2013
I was wondering, does the E11 reduce some sound stage or adds something to the sound signature? I have read that it give a bit of coloration to the sound but not really alot, maybe barely noticeable.
The HD 800 is slightly closer to neutral than the SR-009, though honestly I found both on the bright side, the SR-009 while slightly brighter has absolutely grain free highs unlike the HD 800, which makes the SR-009 less fatiguing on the ears than the HD 800. The reason some people prefer the HD 800 likely has to do with its holographic soundstage and razor precise imaging.
hi2chris
- Nov 18, 2014
So i went for a bit of a drive to the only place that has AKG headphones to try out and tried the AKG K712 and K702.
biggest difference was the K712 was much easier to listen too, the K702 was to sharp so just looking at the two the K712 is worth the $100 price difference to me.
i was happy with the K712 but now im hearing some very good things about the Fidelio X2 and the great value K7xx has enterd the field.
AKG K712 $380 vs AKG 7xx $215 Vs Fidelio X2 $380
short of waiting a few weeks i may just have to bite the bullet since its doubtful anyone would have had the chance to compare all of these. Hopefully MLE can get a review up on the X2 shortly
Change is Good
I guess I'll be comparing the X2 to the K7XX whenever the first drop ships out. I'll even add the HP200, I already own, to the comparison. Should be a very interesting audiophile holiday season
Abula
- Jun 12, 2003
My X2 will be here Tuesday. Hype commencing in 3....2...
Really looking forward...... cant wait....
tl;dr Change is loaded.
- Mar 20, 2010
And I am not.
Change has owned the Annie, so should be interesting. He'll be able to confirm, if his memory is as good as his change. Ba dum tiss.
As for the X2 review, it's more than likely going to be put on headphone.guru, so you'll have to wait until then. I will put up short impressions though.
Total: 60 (members: 0, guests: 60)
