Will you be reviewing the
Sony Gold Wireless Headset?
I'm debating whether to pick these up to use with my PS4 and PC, but I'm not sure if the Virtual Surround Sound works with PC or not. I've got a pair of AD700's right now, I've been thinking about picking up a mic and Astro Mixamp for the same purpose, but if the sony's are even remotely close in quality I would much prefer the cleaner wireless setup. Also, is it possible to have the Astro Mixamp hooked up to a PS4 and PC at the same time and get the virtual surround sound from both? Basically I don't want to have to switch wires back and forth.
I'm not MLE, but I currently do have the Gold for review.
Only had them for 2 days but my early impressions are, they dissapoint in wireless mode — as expected. Then again, I know it's a $100 wireless headset that works both in wired and wireless modes, just that it doesn't so good when running off the PS4 or PS3.
The issue is that in wireless mode, there is a lack of dynamics, as if the Gold is running with no energy. Everything is dull, too soft, muddled, and it's just; boring. This was the same reason why the Pulse Elite before was so underwhelming, even when cranked to the maximum volume.
Connect the Gold (or Pulse previously) to an amp or even to the DS4, the entire headset wakes up. Unfortunately you lose funtionality when being wired of course... which brings me to the next issue; the Gold's VSS.
Sony's VSS is very akin to that Dolby's PLIIx. Take a stereo source and upmix it to 7.1, you get soundstage but you get no imaging which means it's almost completely useless.
So unless you are really, really, bothered by cables, I'd say just stick with your AD700 and get a Mixamp.
Alright guys. I have a favor to ask...
Try to find as many headphones with detachable 3.5mm or even 2.5mm cables. Stuff like the Sennheiser Momentum on ear, which has a 2.5mm input (a cheap 2.5mm to 3.5mm adapter will ensure the Vmoda BoomPro will work on it).
I just wanna have a list of headphones to use with the BoomPro.
For starters:
Philips Fidelio X1
MrSpeakers Mad Dog (not sure if the newer models use xlr)
Sennheiser Momentum (needs 2.5mm to 3.5mm adapter)
Sennheiser Momentum On Ear (same as above)
VMODA M80, M100
Audio Technica M50x (!)
Monster DNA, DNA Pro
Nuforce HP800
I also believe the HD558 and 598 use 2.5mm inputs...
They do, but there's one issue: the HD558 and 598 has a locking mechanism inside their 2.5mm jacks.
Which means, you need to get someone who does the same exact grooves as Sennheiser has done on their stock cable right up at the 2.5mm connector. It's almost proprietary, no idea why Sennheiser thought it was a good idea.
Something like this: http://www.amazon.com/Replacement-Audio-upgrade-Sennheiser-Headphone/dp/B00FYQ1JRI
