- Mar 20, 2010
I thought you looked at those a while ago and decided you wouldn't really use them.
:blink:
Precisely why I haven't given into my urge to get them.
:blink:
Ah, I see. I spend most of my day on campus so my IEMs and M80 get plenty head time. Well, not the m80 as much but since I got it from the Radio Shack clearance for $40 I can't complain.
Still, those on-ear momentums look gangsta... and like you said... those pads, though... mmmmm. Wish I could find some velours for my m80.
If it works out let me know so I can pay her to do mineI've been contemplating asking a friend of mine if she can take apart the M-80 pads, use the memory foam and re-finish them in velour. I may order a second pair from V-Moda and see if she can work her magic on them.
Check the front page.So do you not watch movies with virtual surround? As the Astro Mixamp cannot decode DTS?
Chico, Have you used the x1 with the matrix m-stage? How does those 2 pairs?
The M stage rate min output is 60ohm, will it harm the low 30ohm x1?
They pair fine.
What is the 60 ohm spec your talking about?
For music I still prefer the iCan over the M-stage because of the switches on it.
It says on the spec sheet, the lowest impedance output for m-stage is 60ohm. X1 is rated 30ohm, so will the m-stage higher output do any damage on the low imp x1.
Still don't understand about this impedance rate relation between amp and cans, need to learn more...
You gotta be kidding me...just got my ma900s!
These are the most comfortable headphones I've ever worn. I will never view headphones the same way after buying these. I prefer the sound signature over the ad900x. They're less fatiguing and sound great for all genres.
Anyways, just felt like chiming in and thanking you for the suggestion on this badass headphone.
I noticed with the PLYR1 that when I navigate the PS3 XMB...the initial first UI "click" noise when navigating the menus is very soft almost inaudible (couldn't hear it until I bumped up the volume). I also occasionally hear a brief popping/clicking noise when going from silence to audio. I can consistently reproduce this in DVDs by jumping between the different pages for scene selection. Bringing it up because it doesn't seem to happen on the XP400s or maybe its just not as audible.
Is this like due to changing of source or audio format or something like what people complain about with some audio receivers? A normal occurrence on some headphones?
