sweet, works now. saw that option earlier and i thought i had tried it.. but guess not. thanks!
Yeah I'm not a huge fan of this software. Intuitive, easy to use GUIs are not Creative's strong suit apparently.
On a different topic... I feel like either the DAC implementation, or the BlasterX software, or just the amp...something...is not as good as the E5. (And by extension probably the X7.) Neither of those use "BlasterX," and I think there is a difference (if I remember correctly) between BlasterX and the software used on the E5 and X7 if I remember correctly? I think BlasterX is used on the G5, also there is a free version of it available from Creative. Like the G6, the BlasterX I am familiar with does not allow more granular fine tuning of the surround level, unlike the E5 and X7, which do. So although the G6 uses the same chip as the X7, my suspicion is the audio software is different.
Putting aside those differences, I actually believe this mostly based on the EQ quality of the G6 vs. the E5. One example: Hotel California, which is my go to test song, if you bump up 125hz to the max 12db, it is still listenable on the E5. A little boomy, too deep, but still listenable. On the G6 it becomes completely, totally unlistenable goopy blob, like my head is underwater. Same for the other bass frequencies which is all I tested tonight. At + 6db on the E5 it is even nice and deep at 62hz, on the G6 it is OK but there is a lot of distorted bloat to the slam of the bass. For example 6db @125 & 62hz, at 03:56 on Hotel California listening to the drums, it is deep, slam, not boomy... on the G6 it is very different. Honestly it sounds like I remember the E3 bass sounding when you turned it up too high.
Even flat, when I cue in on certain parts of the song, for instance the two "boom boom" slams of the bass drum at 00:53 at the beginning of Hotel California, the E5 sounds better. Deeper, more resolving bass in my HE-400i. G6 sounds a hair less impactful and less body.
None of this is scientific, I didn't use a volume meter or do this blind or anything. Just tried to adjust by ear and go back and forth (for a while, lots of times.) I have heard this song thousands of times, probably, so I feel comfortable making these comparisons.
Curious when this is out there in more experienced hands if impressions will be similar. MLE I hope I am not stepping on your toes offering these drips of initial impressions before your review is out. Not my intent and I am very much looking forward to your review. This is purely speaking to the music quality, not the virtual surround. For the VSS, I remember my initial impressions are the VSS when implemented has more edge, is a little shriller and brighter than both the E5 and X7, but I have not been able to really sit down and compare rigorously so was hesitant to put it out there. (This is based on playing Call of Duty which I have 21 days of total game time on, so for audio stuff I find a lot of things immediately apparent when switching.) But I am beginning to think this product for whatever reason is not of the same caliber as those two, decoding aside. For the X7 I would understand why, the the E5 it is sort of confusing.
All of this was on stereo, all effects off except for when the EQ was engaged, on an HE-400i straight out of each unit with no external amp.
