Deaj
Here's a look at the build I'm currently working on...
Here are a few images of another finished Magnum V8 / Rholupat Vanquish wood cup build - this one using a Shipibo slim block/gimbal set. The cups are a little beat up as they were used in a test build that was sent to friends for evaluation with no expectation that they be treated delicately. As a result I'll likely keep this set for myself (can't look at them and listen to them at the same time, and I'd rather listen to them - they sound magnificent!)
Now I wait patiently for these cups to become available again....
If you disassemble these and send me the cups, I'd be happy to pop them on my lathe, give them a light sanding and apply a couple of coats of finish for you, no charge. PM me if you're interested.
What a generous offer! Thank you
I made disassembly a bit difficult for myself. Assembly and sealing are all wood glue. They're solid as a rock and I'm confident in my work so worries there.
I am possibly looking to build a couple more headphones. I'll send you a PM with a related question.
Thanks again
Here are a few images of another finished Magnum V8 / Rholupat Vanquish wood cup build. As a result I'll likely keep this set for myself (can't look at them and listen to them at the same time, and I'd rather listen to them - they sound magnificent!)
They turned out great. Good on shipibo for offering both finishes. Deaj what kind of connectors are those, 1/8”? Also did everything go ok with sealing the cable slots?
Just thinking out loud but how awesome would those earlier chrome gimbals be paired with glossy finish wood cups...
The Magnum V8 builds are starting to pile up over here....
There are three different wood species represented here: Angsana (1st and 3rd headphone left to right), Rosewood, and Mahogany. They each affect the voicing of the drivers - more than I would have guessed, though Angsana and Mahogany are more similar than not.
A friend and I are going spin several new wood cup sets using three additional hardwood species (Boxwood, and two other species I'm hard pressed to remember at this moment). Once these are complete we'll have five sets of ears comparing these six tone wood species cups using Magnum V8 drivers, and boil that effort down to a detailed comparison that I will post here when completed.
______________________________________
These two are my personal builds / keepers. V8 drivers in ~1993 Grado SR325 cups, and V8.1 drivers in Rholupat Angsana wood cups.
If I could only own two headphones I'd choose these two. The Angsana wood set replaced my Sennheiser HD650, the set in the SR325 cups is likely to replace my beyerdynamic DT 1990 Pro (still debating this decision but I'll reach for the aluminum cupped Magnum V8 set over the DT 1990's at most listening sessions. Time will tell.
I'll keep my beyerdynamic 250 ohm DT250 - sometimes a closed back headphone is necessary and the DT250 is my preferred closed back. I have a set of LZ-A4 IEM's for travel that aren't going anywhere.
If someone had told me early this year that my go-to headphones would both be of the Grado variety I would have laughed. My general opinion based on many demos of various Grado models (SR225e, SR325e, RS2e, a model from the Professional series I can't quite recall, others) was that they were a niche headphone with some genres better suited to them than others. Not so with the Magnum V8 drivers in the right cups. Classic rock, metal, R&B, jazz, classical, Motown, blues, acoustic, grunge, country, etc. Everything sounds fantastic through these two headphones!
The process is addictive isn't it? And the variations are endless. Good luck in the workshop....it's the ultimate culmination of the DIY aesthetic for headphones, and also loads of fun.
Those look cool! How do they sound?Those look fantastic, I did a pair of Grado SR125’s with Limba wood shells and other mods way back years ago now....yours are phenomenal!
Congrats!,
