Deaj
Limba wood has been added to my list of wood types to try
The process is addictive isn't it? And the variations are endless. Good luck in the workshop....it's the ultimate culmination of the DIY aesthetic for headphones, and also loads of fun.
Addictive. Yes. Bordering on obsessive for me. After the 4 Paduaks I had to step back for a minute. Still have a set of Black Limba’s from fleasbaby and some V8’s to build. Maybe after the holidays.Addictive seems the right word for it. Thanks! I'll post progress as we go.
Great...I’ll never sell them. I got a pair of PS500’s and we a,b every so often and they are amazingly almost identical. Blew my mind when my son and I did it, we both were guessing which was which ...wild.
Limba wood...they make Strativarias violins with it. (Excuse my spelling)
Can anyone comment on how the V8.1s differ from the V8s?
...Not so with the Magnum V8 drivers in the right cups. Classic rock, metal, R&B, jazz, classical, Motown, blues, acoustic, grunge, country, etc. Everything sounds fantastic through these two headphones!...
I've built multiple headphones, some with V8's and some with V8.1's. The V8.1 driver sets are more closely matched than the V8 driver sets but there's no discernible difference in tuning. Unless you found a really great deal on a used set of V8 drivers I'd suggest buying a new set of V8.1 drivers. If you have V8's installed already and you're thinking about upgrading to V8.1's I'd suggest sticking with the installed V8's.
Hope this helps.
replaced my Sennheiser HD650, the set in the SR325 cups is likely to replace my beyerdynamic DT 1990 Pro (still debating this decision but I'll reach for the aluminum cupped Magnum V8 set over the DT 19
Magnum V8.1 vs Turbulent X
Which one is better...
I am going to use Dalbergia melanoxylon pure Black wood for my cups(I am a science guy to the core...so I specified the exact wood) and damping schemes for bass and treble tuning
Dalbergia melanoxylon is the family of Dalbergia which also contains Dalbergia nigra which is northen brazzilian rosewood and cocobolo (Dalbergia retusa). This wood is top of the family in its genome and is cheaper than cocobolo. Normally known as Banabus or Grenadilla, it is also not that famous and doesn't have a popular name
Dalbergia melanoxylon is the African blackwood and is not to be mixed with African black ebony wood(ebony is matter and brittle which makes it hard to work upon). This wood repels water, life is way longer and is more hard with the most even grain structure. Dynamat won't be needed as this wood is actually body vibration inert(no polish inside the cup)
@7keys I am going to try the best wood I can get because normal wood was not affecting the sound profile for my ears. They all sounded same except for Baltic birch which was mmehh bad. Cherry, padauk, walnut and purpleheart sounded the same. My friend does grado mods and I would be making one with him.
Let's see, if the TOTL wood sounds the same, then I am sorry to report, i cannot find the wood effect on grado's or any headphone after a certain limit. Law of diminishing returns...
Will follow back
Till then suggest me a driver
That being said, the back acoustic chamber dimensions are more important than the wood type used, try to make the diameter of the chamber to be 1.6 times its length, measured from the back of the driver to the grille.
I agree and we blutacked the driver firmly.
Well I have a doubt. If the chamber diameter is 1.6 times to length of the chamber to the grill... Won't it make the cup shallow for the acoustic properties to shine.
By the way I am taking shipibo audio mushroom cups shape to be reference. I just 3D scan it and get the NC value for CNC machine to cut the wood for me.
The Shipibo Audio full size cups..
By the way, main difference would come from driver..
Tell me an amazing driver
Not going Epsilon way, as it is just too neutral, which becomes bass weak in grado design and treble also become roll off which gets me a A shape response sounding a little too weird. Was not able to tune it..
So Turbulent X, Magnum V8.1 or Nhoord
Change the cups to the cabinet and it becomes John Borwick quote from his book."Blutacked" the driver into the cups is not a good practice IMO, you need to press fit them, the drivers frame must be in TIGHT direct contact with the wood, which requires some precision cup machining.
The longer the acoustic chamber the higher in amplitude its ~2kHz resonance will be, an acoustic chamber 43mm Diameter X 27mm Length is about right.
Have both the Epsilon R1 and G1, the R1 is anything but "roll-off" and the G1 is anything but "bass weak" to my ears, so you may want to check your other "variables".
By the way, the drivers are just an "ingredient", granted there may be the dominant one but everything else, cups, ear pads, cables are equally important when building headphones from scratch, even the most capable drivers will not sound good in poor shaped cups or unsuitable ear pads.
