Oct 8, 2014 at 8:22 PM Post #3,226 of 4,997
yup the x are the v5's . We do have a list of compiled reviews of the magnums at the following link : http://turbulentlabs.com/drivers-reviews/
Cheers,
Jin
Oct 8, 2014 at 11:27 PM Post #3,227 of 4,997
I redid my build tonight with my Magnum X drivers and my first pair of home-made cups...well, not cups, a pair of inner sleeves. Next project, full woody cups....I ran into the same issue with the solder. Pooped my pants thinking I had burned off the pad...not so. A little perseverance, and running my solder from the patch the voice coil runs to (I know, I was scared $h1tl355 I would burn it out too...) and I got everything set.
Not the greatest solder job of my life, but it works (that's foam tape around the drivers you see)...
The cups/inserts look good.  Keep in mind, a few blemishes is what we call "character".  It also isn't bad when one has one-of-a-kind cups either.
Oct 9, 2014 at 12:45 PM Post #3,229 of 4,997
  Do you recommend any Grado headphones for the Magnums? For example is it any advantage of using SR225 over SR60?
You will be replacing the drivers in either of them with the Magnum Drivers. I suggest getting some wood cups and placing the drivers there and using a Sony headband or the Auvio headband. That way, you don't have to "waste" a Grado driver if you bought a Grado headphone
Oct 9, 2014 at 1:26 PM Post #3,230 of 4,997
Thanks Wje :)
Oct 23, 2014 at 7:48 PM Post #3,232 of 4,997
It's my question too.
Unfortunately there is no place to buy a Grado headband....but there are some others you can use in its place...
There are plenty of cheap versions of the Urbanears, plattan headphone around, and that headband works nicely. You can also use the Sony MDR7506's one, and it can be had as a spare part for about $20 from a few online sources...
Oct 23, 2014 at 8:50 PM Post #3,233 of 4,997
Trew Audio has the Sony 7506 band.
http://www.trewaudio.com/store/Sony-7506-Replacement-Headband-and-Cups.html
The band is $19.95, plus about $10.00 in shipping.  If you buy 2, the shipping might fall at about $13.00.  The only have a once-yearly sale with free shipping.  Trew Audio is a solid company and if you get the order in earlier, they usually ship the same day.
Another good point about the Sony 7506 band.  With this headband, it allows you some flexibility on the axis to tilt the cups.  However, it doesn't permit a full swivel of the gimbals like Grado does.  The big bonus here is that you will never get a twisted and bent up cable like you would with a Grado headband.
Oct 24, 2014 at 11:30 AM Post #3,234 of 4,997
I really like this headband.
Nov 16, 2014 at 9:50 AM Post #3,236 of 4,997
Here you go :)
http://turbulentlabs.com/turbulent-x-headphone-driver/
Nov 17, 2014 at 11:16 AM Post #3,238 of 4,997
Edit: Posted in wrong thread.  The post is now here http://www.head-fi.org/t/119314/post-your-grado-mods/5610#post_11053408
Nov 18, 2014 at 5:05 AM Post #3,239 of 4,997
If anyone with CAD experience would be interested in 3d-printing some Grado gimbals I would be willing to help out by providing a printer :p
should be easy to make for someone with CAD experience, I have none tho..
