Hey guys!! After buying a set of Magnum v4s from 7keys (thanks again, man!!), I shifted into my usual OCD-research mode and read through this entire thread, front to back. I've been enjoying these as a very different sound from my usual stuff, and picked up a few other sets of earpads to try to tweak the comfort (and, possibly, the sound) a bit. Unfortunately, when I finally sat down and went to switch the pads, I managed somehow to pull one of the cables off the driver
. (In case you were wondering, no, I didn't do anything crazy, and I wasn't rough with them-- stuff like this just happens sometimes, especially with custom, enthusiast-built pieces). I've tried to take a picture of it and circle the separated cable in red:
What I'm wondering is this:
would I be better off sending this to someone for repair, or should I attempt to solder the connection myself?
Relevant info:
- I have never soldered anything of actual import in my life, although I bought a small soldering iron and kit several years ago.
- I have been toying with the idea of picking up a set of SR60s used so I could start learning more about how headphones work and how to modify them, including the ability to solder.
- The soldering equipment I currently own is a little Bernzomatic hand-torch with a soldering tip that I was unable to find a model number for, pictured below.
- I would very much not like to destroy or severely damage these headphones.
If this is going to be anything even slightly more difficult than you could teach a monkey to do in 10 minutes or less, then I'd probably prefer to send it to someone else to be done. (At which point, I'm open to suggestions!
). But if it's a really easy fix (really, truly, legitimately easy-- not "easy for a guy like me, who works all day long building wiring harnesses for nuclear submarines" or something), I'm willing to give it a shot.
So, what say you? Be as honest as you'd like-- I'm not going to be offended if the answer is that I'm in no way qualified to try this out.
Thanks in advance, fellas!!
