Eric510
- Dec 5, 2014
I have worried a little about dust, but I try to keep most of my headphones out of direct line of droppage of dust (i.e. under something like an awning) if not boxed. However, for me at least, one of the surest remedies to dust is frequent use... the handling, teh vibration of sound, and even a carful blowing or shaking will knock off any accumulation.
And do not think that your headphones kept in their Grado box are immune. The blue foam used in the HP1000 headphone box, for example, crumbles over the years and can fill Grado headphone openings faster than room dust!
That's pretty much what I was thinking. As long as we don't neglect our headphones, somewhat consistent use should do the trick, right?
i vacuum mine (very carefully) once in a while.
but as the drivers are moving things, displacing air, i don't know if it's even needed to do so.
I've THOUGHT about doing this but... I'm kinda scared to. Anyone ever considering a little blast of air from one of these? I'm guessing if you hold the Grado above your head, give it a blast, gravity should take care of the rest, no?
