Andriko
- Jan 23, 2012
snip
Do any ultrasones compare to the hd 558 or ath m50 or srh 840?
In other words, do any ultrasones have a closed back, similar soundstage and sound quality to the hd 558, and bass from the ath m50?
From what I've gathered, the srh 840 is all of that above
Hello. I'm going to buy some new headphones after ruining my old Bose headphones and I want to step it up a notch. I'm also planning to buy a Maverick Tubemagic A1 hybrid amp so I want some headphones that benefits from that. Some other requirements:
- Comfortable (got kind of a large head)
- Detachable cable
- 200-250$
- Noise-proof (by that I mean headphones that doesn't leak too much sound either in or out)
They will be used primarily for music-listening. I listen to a lot of different stuff like some jazz, classical piano, orchestras, post-rock, metal, techno and so on, but for me it's more important with a crisp and detailed sound than lots of bass.
Hello Head-Fi'ers,
I currently own a pair of AKG K 450 wich make me quite happy. They're also perfect for portable use.
BUT, as a Head-Fi'er, I can't remain only "happy" with headphones, I want my headphones to take me further than only happy. In addition, I've received some money for Christmas. So, I've (almost) decided to buy new headphones.
By browsing Head-Fi for several months, my choice has narrowed to the Alessandro MS1i's (which are more "versatile" than Grado SR60i's as I read [I don't speak about the SR80i's or higher because they're damn expensive here in France], and are "home-upgradable").
I listen to plenty of genres of music, and I'll soon start to listen to those I don't listen yet. In short, I'll listen to absolutely all genres of music, with a predominance of metal of all genres.
I'm not searching extraordinary soundstage, neutrality or very specifical things, I just want my music to make me fly (OK, with a ~$120 budget).
So, four questions :
- Is it worth the cost to upgrade from AKG K 450's to MS1i's for home use ?
- Would you advise me to buy other headphones than the MS1i's (I'm thinking about the Brainwavz HM5's) ?
- Would you advise me IEMs, instead of full-sized cans, that would be better than the MS1i's, and still under $120 ?
- Are the MS1i's "bad" with electro, dubstep or rap, or is it just that there are better cans for these genres ?
Thank you.
Why don't you take an another AKG, K271 MK II, very good can ! http://www.lesnumeriques.com/casque-audio/akg-k271-mk-ii-p4211/test.html
They are totally out of budget135 € instead of 87 for the Alessandro's.
