Hi all!
Not exactly a question on chhosing phones, but I'd rather not start a new thread.
I've bought new German Maestro GMP 8.35 D headphones, and I'm very disappointed with it's sound. Specifically - there's a huge spike on frequency response around 1-2 kHz, which makes the sound too harsh and masks the higher freqs. Someone told methat as far as the phones are new they might change sound after burn-in. personally, I don't think so, but it won't hurt trying anyway (or will it?..).
Can you recommend me the technique of burning new phones in? Currently I'm using pink noise 20 Hz - 20 kHz in a loop on above average volume, but I'm not sure it's a good idea.
Thanks in advance.
I'm not a proponent of burn in either, but pink noise for a few days ought to do it.
I need recommendations for a good full-size headphone, ~$300.
I really enjoy a strong mid-bass (125 - 250 hz). I am very sensitive to and fatigued by a sharp high-end or loud super-deep bass. I tend to like rolled off highs. Sennheiser PX-100 are pretty much my favorite headphone of all time, for example.
No Sennheiser or Grado suggestions please.
So far I am considering:
Beyerdynamic DT 990
Ultrasone HFi 2400
AKG K 702
Which one am I likely to like best?
The PX100 is one of my favourites as well. I think the DT880 would be a good full sized alternative. The DT990 are very strong in the bass and highs, and the K702 are leaning on the bright side as well. Your Kicas should drive the Beyers without problem.
Hi guys, as school is aproching im looking to buy a new per of headphones which are going to be on my ears from 7AM-4PM, of course not during the classes, so on avg about 4-5hrs a day.
So i need something thats going to be very very comfortable. I dont really car about the size of the headphones, but I do care about the look. dont want everybody to be starying at me at school. so I was thinking of AKG K701/702 but I've read that some people experince pain after awhile, also I looked at ATH- AD700. I know they are very very very very and very comfotable, but they sit loose on the head, is that big issue or not.. please be free to talk about other headphones also, I mentioned these because so far these are the ones that i like(the look, and overall soundwise) but if you think there are better ones let me know.
Thank you!!
You'll be wanting something with reasonably rugged construction, good isolation (so you don't bother people around you), and probably foldable or collapsible in some way to ease transport. The K701/2 and AD700 do not fit any of these criteria. Here's a bunch to look into:
Beyerdynamic DT770: rugged but kinda big, strong bass, several impedance models to choose from (go with the 32 ohm version if you don't have a portable amp)
Sennheiser HD280: excellent isolation, folds up
Sennheiser HD380: like above, better sound and comfort, but more expensive, folds flat rather than collapses
Senn HD25-1-ii: smaller and more portable, even better isolation
Beyer DT1350: similar to above
Audio Technica M50: full sized collapsible, moderate isolation
Shure 840: like above, better isolation, heavier
