Thanks Armaegis, really helping me out here.
I've narrowed down my choices to end up noticing I'm more headed towards portable headphones (a bit more all round and less pricey) than full size ones, so I guess I'm not really in the right section anymore.
Went to the store today and got to test a few models, so I'm doubting a little before really going ahead and buying.
K518DJ - Indeed, a small bass cannon but nothing too bad. Clamp is hard but I think it'll loosen up with time (had the same thing with my WeSC heating up my ears, while now I can wear them a whole evening without a hitch).
Sennheiser HD25-1 II - Seemed like nice sound but unfortunately, one of the headphones (L side) didn't work properly. Isolated well too.
PX-200II i - Seemed very portable, foldable is an extra, but sound-wise wasn't that impressed (didn't get to use it for a while). It was clear, but nothing too special. Might still get them because the portability is amazing. Isolation wasn't complete but it worked.
HD280 - Sound seemed very good, but it was a bit too big imo to use as a portable one. Maybe once I look for a dedicated home headphones I'll look into the full size Sennheisers (HD5XX series come to mind).
Realizing that full size headphones are just a tad big for going around, I'll settle with something that has good sound quality while being at a smaller size (and smaller to wallet).
First time using Sennheisers, I got convinced that it is actually a good brand with good sound quality.
For now, I'm leaning towards either the K518LE or PX-200IIi, since I didn't find any bigger headphones by AKG to test out and Sennheisers were a tad too big (or too pricey) for me.
The PX200IIi is versatile, but I wasn't impressed with the sound too much (then again, I only tested it about 3-4 minutes in a busy store).
The K518LE is indeed quite bassy, but not TOO much (I tried Monster beats and that has TOO much bass imo).
Other suggested Sennheisers were also not easy to find (and even less to try out).
Changing from WeSC to either of these will probably be noticable be it any kind of source I use right (I found it to be "wider")? Wouldn't regret changing to either of the 2 above?
P.S.: I saw a store selling AKG K520, but can't find that much info about them. Any good?
Still open to suggestions, I'll read up on the other brands but yeah, so much choice for a beginner, and being a student I can't afford top notch or different pairs.
It's probably not recommended to read too much as avid fans will suggest different types, I'll end up being more confused after than before coming here.
I'll ask for another suggestion when the time comes for bigger (and better, I suppose ^^'') headphones.
The K81/518 is like a little bass cannon... not the most articulate I've heard, but it thumps. The clamp is relatively high as well (makes for fantastic isolation, less so comfort). The full sized AKGs aren't that convenient for portable use since their headband structure is rather large.
The Senns HD280/380 are indeed kinda large, though not moreso than most other full sized circumaural headphones. I found the 380 quite comfortable though. The HD25-1-ii is much more portable and has excellent isolation (I would put all three Senns around the same rank, with the HD25 maybe slightly edging out the other two). It doesn't fold up in any way, but the overall size and weight is much smaller and is very durable. Soundwise, the HD25-1-ii is slightly U shaped with good punch in the lows and highs (which some find a bit fatiguing). The HD380 is just as defined but not as punchy. Comfortwise I give the nod here to the HD380.
As for the other brands, just keep reading!
In general, the WeSC/Skullcandy/iFrogz/etc are lousy headphones. Some have great warranties though, if you have a habit of breaking headphones.
Bose is ok, comfort generally very good, noise cancelling tech is very good, sound quality itself is nothing to write home about.
