Roflwafflelawl
- Dec 31, 2010
Quote:Alright so I had a thread but had 2 replies, both of which did not help in the least so I'll try my luck here. Take into account I have just this day (so about 8 more hours) to decide as leave Cali in less than a week and need them shipped before hand. So the faster straight forward answers the better
So here goes:
I'm looking into buying some Beyerdynamic headphones (Heard soundstage was great, good bass without ruining other layers, and heard they're like clouds on your ears *shivers in delight*).
Problem is I only have amazon gift cards to use and the budget is set to $210. Now I was going to go for some DT880s or 990s until I realized they're in the 250-600ohm range.
That's where my problem arises. I do not plan on getting an amp (at least for a long while). Reasons being : I don't want to spend extra money (since Im at a set budget) and I do not want another device to have to manage.
Now this may not be TOO big of a problem as long as my source is powerful enough. Well it's not. This is going to be cans for my itouch4 and my itouch4 alone. So it will be mobile. Size isn't a problem (I like big phones imo).
After searching and searching I found that the DT770/32ohm premium is more or less what I'm looking for. Thing is I've heard mixed things about them in terms of needing an amp and not.
As I'm going to be in public the pair needs to be closed, which narrows the options significantly. Also needs to be driven by my itouch, which narrows it even more.
So can anyone give me a pretty straight answer? Will I be satisfied with the DT770/32 without an amp? I've looked into ATH M50's, KG271, Senn's 555s (and others) but cant stress enough that I want the oh so delicious comfortability of the beyers ear pads (and sweet soundstage, though Im sure aren't the BEST).
But if you think I will be disappointed with them, is there a pair that will fit my need (either of the listed or of something I did not list) ?
I listen to a broad range of genres but mostly progressive house, club, dubstep, metal, some pop, old school rap. If this helps.
Edit**: Forgot to mention that I am looking for full sized (obviously) around the ear circum phones. Closed back of course (unless you know of an open back that has minimal leakage)
ATH-M50 with Shure 840 pads are amazing with great soundstage and comfort that rivals Beyer IMO. The DT-770 32 is a great can (only the 600 ohm has a sonic difference). I am not sure they will provide enough unamped.
Do the pads need modifications? Or is it a take off slip on type deal?
And like I said, I want to stick with the Beyers (Im an audiotech head and want to stray away from the brand until I go back to Japan this summer). And Im more of soundstage then bass (which I heard the M50 having more of? Correct me if Im wrong)
edit**Looking at other phones in the mean time as to not waste any time and stumbled across the Sennheiser HD595.
How are these compared? Unamped of course.
As it stands my ranking (from wanted to plan B plan C) is
DT770/32
M50
HD595
