Originally Posted by
roguegeek /img/forum/go_quote.gif
I have a friend at work asking about a recommendation and I want to get all of your feedback before I recommend anything to her.
- Budget of $100. Could spend a little more if there's something significantly awesome out there that will work for her.
- Plans to use them at work and at home. All indoors.
- She's shy about her sound leaking out, so they should be closed cans.
- Listens to rock, alternative, and a fair amount of female vocalists. Usually listens to low quality source material like Pandora.
- Connects directly to an iMac or portable iDevices. Will not be using an amp, so it should be fairly efficient.
- She doesn't know the signature she's looking for and physical comfort is key. Says she generally feels her head pounding after a couple hours of listening with some other cans she has (will identify the current model soon), so you'll probably want to recommend something with light clamping force.
Have at it.
A quick update on this. I let her try my MDR-1R and SRH940, each for a day. Figured it would help her and I get a better idea as to what she's looking for since I consider them to be very good, contrasting, closed cans. She preferred the SRH940 because "they sound sparkly" and are "tingling (her) senses". I figured this would be the case considering the music she listens to. She didn't hate the signature of the 1R, but she did hate the pleather as it made her head too hot. She's very sensitive to the clamping pressure and material.
So knowing the original feedback and reading her new feedback which looks like it requires velour pads, what are you guys thinking now?
