Plug--I've had no problems, despite using an iPhone with a very big/thick protective case.
Comfort is a very individual thing. I can only say that of those who have tried both, fewer will have concerns about the Senn. The earpad material is very different between the two.
Have not yet heard the (reported to be bassier) Momenmtum. I can tell you that the Amperior has a very good sound stage for a closed can, and is excellent on the left to right spectrum. It certainly does not have the up/down + depth and positioning of the much more expensive and open T1 (but then I would be shocked if the Momentum did either).
Quote:Have you considered the Amperior?
I did read some reviews on them, I'd have to listen to them in store to decide though. I read the following
The plug end is too big for portable use? (true or false?)
The earpads are on ear - are the comfortable (because i tried a pair of Grado's once and they were unfortable after a while
The soundstage of the Amperior is not as open and wide as the Momentum? (True false?) not really sure what this means though
thx
