WarriorAnt
- Jan 9, 2009
Why did you pick WAV over AIFF?
I guess this was really my question? i would have kept the AIFF files and simply transferred them using something like XLD.
The PureMusic guys recommend to use a firewire or ESATA HDD interface if using a USB connection for your DAC if possible, they only want a USB HDD connection if using optical or coax directly out of the sound card.
I though that I read that WAV doesn't support tags, but this may differ on PCs and Macs.
Hey Grokit,
It's not going from my usb drive to my dac, but to the BDP-1 which is a digital player that connects to a dac. Also, there is no firewire input on the back of the BDP, just usb. I did find an answer on the Bryston board. It seems that jitter is not an issue until the file is opened and is playing, until then it is just a file. So it's just a file until it gets to the Juli@ sound card in the BDP which means I don't need anything other than a standard issue usb cable.
No reason for picking WAV over AIFF. Do you think that AIFF is superior to WAV?
So you are using your computer to rip and download music but then transferring to the BDP-1 USB drive for streaming, can you have the drive mounted on both or do you have to unmount from the BDP-1 and mount to your computer etc.?
I would have thought that the streamer would be fed by a digital output from the DAC out of your computer. It seems like you are exiting the iTunes universe for something much more specialized with the BDP-1 if dBpoweramp is creating files just for it but I don't know really...
I have all of my music in ALAC format, which works great except for the fact that when I try to transfer my library to a Windows formatted HDD most of it won't copy. So I was thinking of re-ripping in Windows and decided on AIFF because of the tag thing. But I never got around to it after a few dozen CDs or so, the whole notion of re-ripping everything kind of faded away into the ether as I don't boot into Windows much on my Mac Pro so that's as far as I got.
Your system seems "different" to me, I think I would either stream straight out of my computer or get a DAC/streamer like maybe a Transporter or a Chord all in one unit to do it externally, does your BDP-1 function the same whether you use it with the BDA-1 or the DAC-2?
My thinking is that when it is already in AIFF form on the CD any conversion to another format such as WAV in this case is a conversion that can add error as opposed to a straight transfer of the AIFF but I'm not really sure which is why I'm curious about all this.
The other item worth noting is that of all the "processes" being discussed, the one which is most prone to errors is CD ripping. If you can get past that stage with the music unaltered I don't think you will see any appreciable difference between file formats, either compressed or uncompressed. For me, the ability to tag is huge which eliminates WAV.
Weather Update ~
A bit bleary-eyed but, in following this thread this morning (and shedding my own previous impressions), after further review neither AIFF or WAV are native files to the CD. The CD's native file is the 16-bit PCM data file. AIFF/WAV are merely headers with byte-ordering information (Bond: "Shaken, not stirred..."). And neither are superior. In my view, all choices regarding the introduction of a file to be played in one's system is hardware/software dependent.
Take the new Bryston BDP-1 or example. This well designed handcrafted Linux based digital player seems secure in its place inside the digital domain. Reports have returned that playback is smooth, refined and docile. The Devil himself could be lurking inside the chassis and you'd never know it by the player's output- a pure unadulterated signal.Decisions regarding input should come much easier with gear like this.
With each generation, revamp or reconfiguration of my system, comes the questions anew: uncompressed/compression; which container? What's more, I noticed each time my gear brings new tech to the table, the choices are less relevant thanks to advances. At this point, the only remaining question for me is "Do I own the disc?" (sure, space, tags and other decisions await but nuthin' that would interrupt my serving of tea)
This Weather Update is brought to you in part by Silent One and the groundbreaking Jazz group Weather Report. Currently playing their hit "125th Street Congress" from the album Sweetnighter - 1973. Between my emerging W4S DAC-1 and my solid WA6SE, the track sounds amazing... especially at this hour!
Agreed. The outset is quite the hurdle. When you consider the amount of time many of us put in to our tube gear operations, you'd think we'd also have the patience for 'ripping.'
Do scratches on discs make a difference to how well a CD can be ripped? If they don't skip or jump, does it make a difference?
My local library CD's look like somebody cleaned them with steel wool.
