Silent One
What silence said... then nothing.
- Aug 9, 2010
Quote:You beat me to the punch! I was just fixin' to comment on your photograph. Underway, my midnight to 0300 hours listening session. First up, "Rise Remixes" by Sitar player Anoushka Shankar. Daughter of renowned Indian Sitar player Ravi Shankar, who also fathered Norah Jones (half-sisters). Her remixes are sounding good tonight!
Looking at your photograph, if the visual vertical display of headphones are any indication of preference, my Denon's are in trouble. And if low-man on the pole isn't enough, they're being subjected to the most heat... and that's cold!Although your P/S has more headroom it generates less heat.
Looking forward (Summer?), "Decoupling" your gear may yield further gains in sonics. As it stands, you've five items that are all connected - four components and the lamp itself. Which, by the way, may be producing harmful micro-vibrations on its own. But anyone of the four components could be interfering with one or the remaining three components. Isolation and/or placement could take your Woo up a notch.
How you're addressing the Peas & Carrots (keeping digital & analogue sources separate when/where plugged-in) makes for another post, another time, another place... cheers!
I knew I should have decorated with audio gear as first priority!
I'm fighting it, but I'm already thinking about a makeover to better accommodate my gear... Maybe I can get a Head-Fi version one of those HGTV interventions?
As for the Denon's, thet are in comfortable reach...
AH-D7000 ~
O.k, that comforts me!
