Thanks - I'm sure once I get the WA2 in a couple weeks and I am blown away by how good it sounds with whatever Jack ships it with, I'll relax considerably. One reason I decided to go with the WA2 rather than the WA6SE is it's tendency towards a warm, tubey sound more than the WA6. I figured this would give me a little more latitude in tubes, since it is very easy to make things bright with cables, etc. After describing what I was looking for to Jack, he recommended the 2 instead of the 6, which aligned with other's comments here.
While I like soundstage and transparency, I crave the liquid, lush and sweet character of tubes that I used to get from my Conrad Johnson and Quicksilver Audio stuff back in the Quad ESL-63 days. "Juicy" would be the single most descriptive adjective I could apply to the sound I like.
I was always more of a Conrad Johnson guy than Audio Research. I owned a CV-7 and MV-75 for several years (originally with ProAc Tablettes). Replaced the MV-75 with the Quicksilver monoblocs after I got the Quads
In the mean time I need to fab an RCA breakout box for the Duet to get rid of the breakout cable supplied. I am going to try and fab a small box attached directly to a sub-min D so I just have an inch or two of some left over vintage hookup wire (I still have some solid Wonder Wire as well as the original MIT stranded chassis wire). I'm sure that will help significantly.
My long term DAC plan is either a Metric Halo ULN-2 or Wavelength Brick unless the new Rega DAC gets some good reviews (I always thought my old Rega Planet CDP sounded great).
So I did find a matched pair of 5998's at least
Are the Russian 6H13C's OK sound wise? Most of the tube rolling threads here seem to dismiss them compared to the RCA/TS/GEC options. I also don't recall seeing any comments about the GE JAN 6AS7GA'a either. Been away from tubes for about 15-20 years, so I'm a little paranoid.
I don't think the Russian tubes are as good as the US and UK varieties, but they are plenty good enough that you wouldn't need to trash your amp! Same with the GE 6AS7GA - not my favorite, but great for the money, and to have a back-up pair or three
